Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 08-24-2009, 07:46 PM
pmurdock is on a distinguished road
success! big piece mounted and turning!
Boy - recently had a few jobs come in that were huge (for me anyways! <grin>)
Check out this photo I snapped of this piece of 4140 prehard.
9" diameter - 12" length
225 pounds of pure steel mounted in a Haas SL-30 with 10" chuck with tailstock.. I tell you it was scary prepping the hole for the tailstock.
I put 300 psi on the chuck pressure just to be on the safe side. Is there a general rule on how much psi one should put based on weight of material?
I used a fork lift with some lifting belts to mount the piece in the chuck - wasn't too bad at all!
cheers!
Paul
Sketchup success in CNC? ZipSnipe General CAM Discussion 10 02-27-2011 10:59 AM
Success!!!! Smitty911 Benchtop Machines 18 03-02-2008 10:13 AM
Success HX6090SE pedroman Laser Engraving & Cutting Machines 1 05-25-2007 09:02 PM
R2E3 success story bkraz Bridgeport and Hardinge Mills 3 12-02-2005 02:34 PM
At Last, Success is Mine! jstuedle CNCzone Club House 4 07-06-2004 10:26 PM
