Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 08-14-2009, 10:57 PM
11toma is on a distinguished road
HL-2 monitor very dim
I recently bought a HL-2, the monitor is very dim. Is there a way to correct this problem? The machine is a 1997 and has a black and white screen, unlike the normal black and orange. I appreciate and help in this matter. Thanks Tom
Old 08-14-2009, 11:06 PM
If you take the sheet metal cover off the back of the control box you may find a little knob sticking out of the side the monitor that adjusts the brightness.
But then you may not; one of our old machines has it, one doesn't.
Old 08-14-2009, 11:17 PM
I will check it out tomorrow. Thanks for the info. Tom
LCD Monitor Dyad1 Fadal 25 10-14-2011 06:54 AM
Need Help on Monitor Hang flomatic Mazak, Mitsubishi, Mazatrol 15 07-28-2009 04:05 AM
Need Help!- No Power to Monitor CRT joim Open Source Controller Boards 0 03-28-2008 10:39 AM
monitor rusticr6 Haas Lathes 7 10-24-2007 08:06 PM
monitor CASTLEVILLE Bridgeport and Hardinge Mills 8 10-10-2007 07:37 PM
