Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 07-27-2009, 10:55 PM
MBG MBG is offline
MBG is on a distinguished road
Lets talk feed rates (milling)
Okay. I am trying to program haas mill. I am used to lathe feed rates of .015" inches per revolution.
How do the mills work?
Old 07-28-2009, 05:37 AM
Superman's Avatar
Superman is on a distinguished road
Lathes , generally are programmed in feed units per Rev = G95
this allows you to control the RPM and still maintain the programmed feedrate
Mills on the other hand, can swing both ways (pun), normal progamming is with G94 ( feed units per minute ), this allows feedrate and RPM control to be independant to each other.
setting up a milling program involves many factors, width and depth of cut, # of flutes, work holding, cutter stickout just to name a couple . To fine tune the program separate control of the feed and speed is required
using G95 on a mill is best highlighted when tapping, the programmed feedrate need not be altered if the RPM needs adjustments, just remember to switch back to G94 when finished tapping, or the machine will seem like rapiding all thru the next tool operation.
Downside of using G95 on a mill, if RPM = zero, the machine no move boss
Lets talk about BRUTE machines....WOW carbidecraters General Metal Working Machines 13 05-16-2010 03:23 PM
Feed rates jwest DIY-CNC Router Table Machines 1 11-26-2008 09:35 AM
Feed rates? Rainman229 G-Code Programing 3 02-23-2007 12:47 PM
Lets talk financing carbidecraters General Metalwork Discussion 11 04-18-2006 03:00 AM
Rpm and Feed Rates Xeno General CAM Discussion 35 02-23-2004 05:06 PM
