Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Bar Puller VS Bar Feeder
    Jan 2007
    I am looking into buying a Haas SL 20 and i am debating puller and feeder
    I have roughly ten thousand 1" aluminum turned parts to make any insight
    into this would be appreciated
    Jul 2005
    It can be a wash but there are some differences:
    A feeder can be faster than a puller but not by a great amount unless it can feed with the spindle running so you eliminate the time spent stopping and starting the spindle.
    With a magazine feeder you do not have to spend time loading bars.
    I have a question:
    Why SL20 when the part is from 1" bar stock, why not SL10? Costs less and has a higher spindle speed.
    Jun 2008
    us
    I would like to add another difference. I am using a puller right now because I need to move another machine to get the feeder set up. With the puller I am limited to what fits inside the spindle, about 3 1/2 to 4 feet. Once the feeder is set up I can feed a 12 foot bar. That equals less handling and less scrap.
    Jan 2007
    Ok that seems like good advise, my shop is geared twords prototyping and development, but this job would more than pay for half of the machine in one shot so I can't really say no.
    I do have limited space and as much as I would love to have the bar feeder it sounds like I could get by with a puller for this time.
    Do you have any thoughts on years I have heard that some of the older lathes have had turret problems ?
    Jul 2009
    england
    Bar feed
    I would say bar feed all the way.
    i leave my machine running over night on simple jobs and without bar feed you couldnt do this.
    Come in in the morning and its still machining
    so simple answer to me
    done this for last few years with no problems
    Jul 2009
    england
    Quote Originally Posted by inertialabs View Post
    Bar feed all the way.
    this way you can run the machine all night with nobody there.
    money for nothing
    i do it all the time with no probs
    this would soon pay for your bar feed and lots more
    i decided to go with bar feed and never looked back
    its a no brainer tbh
    for me anyway
    Apr 2007
    USofA
    Barfeed vs barpull
    I have a barfeed on the 10. It is good to get it set and load up the bars and go. I do not use lights out since we have not had a long run job with smaller parts to do in some time. Plus we often do not have large runs on a monthly or by weekly basis just don't have them. We usually have a average of 12-14 parts per run. When I have more I use the barfeed or puller. The barfeeder (it could be just me) does not do well with smaller diameter material and even small material like 3/16 diameter. I use a barpuller on that. Plus a barpuller can take up space for a few jobs where I might just need that extra space for a tool though rarely. We have regretted not putting the bar feed on our 20 though on occasion. The barfeed does take up a lot of space though in a crowded shop.
    Registered HelicopterJohn's Avatar
    Dec 2005
    Seffner, Florida USA
    Bar Puller and Cut Off Combination
    Has anyone tried one of these?
    A friend of mine just purchased one of these for his new HAAS GT10 Lathe.
    http://www.royalprod.com/product.cfm?catID=4&ID=26
    It looks well made and is adjustable for different sized bars and combines 2 tools in one to save you one tool location on your turret.
    John
    Apr 2007
    USofA
    royal tool
    It looks cool. I do tend to part off as close to the chuck or collet as possible and I think the puller would probably space me out a little. That is a smart concept and I could still use Iscar for partoffs.
    Dec 2005
    Royal Tool
    I haven't actually seen the tool in action. My friend has it working and as soon as he gets everything sorted out he will invite me down for a little demo.
    I will let you know how the demo goes.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://www.helicopterjohn.com/
    Jun 2006
    haha funny story about leaving a bar feeder running over night. The first time we left the machine running over night we came back to find 3000 parts with no holes in them, lol. We ran the job all day long for 3 days on the same drill. I changed all the inserts and the drill 30 minutes before quitting time. Shut off the lights and left. By my cycle times and the number of correct parts that were made. The 3/8" drill broke about 4 minutes after I left so it ran for 16 hours making parts with no holes. Luckly we just set up a mill and drill them all out the next day, lol.
    Jul 2005
    I have wondered about Rube Goldberging something together as a broken tool detector to prevent this sort of thing, especially with drills and taps.
    I have seen systems advertised that use laser beams or probes whcih are not cheap but I wondered about a system with a microswitch operated by a little feeler. At the toolchange before, or after, position the turret so that as the tool change occurs the drill nudges the feeler and closes the microswitch to reset something.
    I haven't entirely figured out the something but maybe the M-FIN function could be used:
    If the drill is intact the microswitch closes momentarily and this would operate a relay wired to self latch in the M-FIN signal circuit.
    Immediately after the tool change give the M-FIN code and use the M-FIN relay to close another relay in series with the latching relay.
    If the drill is intact both relays are closed so the M-FIN signal circuit is closed, the machine continues and turns off the M-FIN relay which opens the M-FIN signal relay and the machine continues running the cycle.
    The latching relay has to be reset and this could be from another user M relay:
    Wire this relay in a normal closed configuration into the latching circuit and immiediately after the M-FIN code have the other user M code to open this relay dropping the latch out, then cancel this user M to reset everything for the next toolchange.
    This should allow you to detect several different drills or taps by having the turret move into an appropriate position for each one and would also be adaptable to parting tools.
    Total part count is one microswitch, two small relays and a low voltage power supply.
  • Page 1 of 2 12 LastLast
    1. mazak bar puller qt-10 T1
      By imholta in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 07-31-2008, 02:37 AM
    2. Bar puller programming
      By FUN4ME in forum Haas Lathes
      Last Post: 05-20-2008, 03:55 PM
    3. Need Help!- using a bar puller for first time
      By qnet2 in forum Haas Lathes
      Last Post: 03-05-2008, 10:25 AM
    4. CNC lathe plus Bar Puller help
      By SeaSchell in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-05-2006, 07:44 PM
    5. Mini jaw puller?
      By mikesativa in forum General Metalwork Discussion
      Last Post: 04-18-2006, 12:21 PM
