Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 07-15-2009, 12:00 PM
ChsBrown is on a distinguished road
KITAGAWA ON SL-10 HELP
OK, I have the 6" KITAGAWA chock on the SL-10. It's only been on about three months. I can't get the drawtube nut to come loose. The operator's manual says the chuck has to be clamped, so I tried that first. The techs say it has to be unclamped, so I tried that. I really need some other advice, is there a better tool than the wrench that comes with it? Is there some way to modify it? HELP!!!
PLEASE!!!!!
Old 07-16-2009, 12:28 PM
thum31 is on a distinguished road
HAAS HL-4 chuck help to remove
Hope this helps.
Old 07-16-2009, 12:47 PM
Thanks for the pointer, it's a different way of doing it than the manual says or the tech guys. Anything is worth trying right now.
Thanks again.
Old 07-19-2009, 01:16 AM
Originally Posted by ChsBrown View Post
OK, I have the 6" KITAGAWA chock on the SL-10. It's only been on about three months. I can't get the drawtube nut to come loose. The operator's manual says the chuck has to be clamped,..... HELP!!!
PLEASE!!!!!
Clamped as you should find out when you read my post that thum31 linked you to.
It can be a real pain unscrewing the nut because if you are not careful you round off the corners of the slots in the nut. The trick I have discovered is to keep the wrench held in firmly with the turret, but not too firmly otherwise you trigger a Z servo overload.
Good luck,
3 Jaw Chuck - dramas - Kitagawa pmurdock General Metal Working Machines 0 03-05-2009 11:24 PM
Need Help!- Kitagawa B-08 Power Chuck HiTech General Metal Working Machines 2 02-06-2008 10:50 AM
Kitagawa B-12 petriej General Metal Working Machines 3 09-25-2007 07:02 PM
Looking for Kitagawa TB250 table instruction book Meccbell General Metal Working Machines 0 07-01-2007 10:13 AM
Kitagawa autodex MacMini controller soszi1950 Ability Systems - LPT Indexer and G-Code 0 06-09-2007 06:26 AM
