Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 07-07-2009, 02:19 PM
shawncnelson is on a distinguished road
sl-10 thermal comp
I have a newish SL-10. It's been treating me very well, thank you. One issue I've had is fighting with the thermal comp. I turned off the automatic settings, that helped a lot. Now I'm using the #109 and #110 settings. The only problem I'm having is that the maximum time allowed is 300 minutes. I've installed a thermocoupler on my X axis casting and have found that my machine will heat up for at least the 8 hours that I run it un-attended, maybe more. The Haas guys tell me that there is no way for me to increase #109 more than 300 minutes.
http://www.1dropdesign.com
Thermal Arc PAK 20a scrambled CNC Plasma and Waterjet Machines 1 11-01-2008 10:57 PM
Haas VF-3 thermal comp settings % 8100hammer Haas Mills 2 11-04-2007 11:54 PM
Haas SL-20 Thermal Comp Gomes Haas Mills 3 04-11-2007 07:55 AM
Thermal couple? Tom Brown Casting Metals 3 11-24-2006 08:55 PM
Thermal Expansion mikie DIY-CNC Router Table Machines 2 11-21-2005 09:45 AM
