Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 06-17-2009, 09:00 AM
Lathe Dog is on a distinguished road
Next Tool button
Dose anyone know how to disable the "next tool" button on a hass lathe. I accidentally hit it and crashed.
Old 06-17-2009, 09:05 AM
chucker's Avatar
chucker is on a distinguished road
I cut out a pice of sheet metal and bent it like a U shape and put it over the button
Old 06-17-2009, 09:09 AM
Welcome to the club.
Was your chuck spinning or did you just crash the tool against the part?
I do not know of any Parameter that can disable Next Tool and it lurks there waiting for a repeat performance on my part; fortunately I have been able to avoid it for several years.
I have 'disabled' some keys on my machines by making little covers that go over them; these are fastened to the screws that hold the control panel on.
Many times I have thought about making a full keyguard out of polycarbonate covering the entire keypad with holes at each key location. With this you would not be able to hits keys accidentally so easily and it would be possible to have plugs to blank off any key.
Old 06-17-2009, 09:13 AM
I just broke a 10-32 tap off on the measuring arm. Good thing it wasn't a boring bar, it might have ripped the arm off.
Old 06-17-2009, 10:19 AM
On the lathes I think there should be a Setting or Parameter called 'Next Tool Z Retract' so that you could put a value in there to have the Z axis pull back before rotating the turret when you press Next Tool.
Haas-Apps where are you? Hint. Hint.
Old 06-17-2009, 12:25 PM
Haas_Apps is on a distinguished road
Geof,
I will discuss it with software today. 'Can't make any promises.
Old 06-17-2009, 12:34 PM
Originally Posted by Haas_Apps View Post
Geof,
Gee you are fast.
Old 06-17-2009, 03:37 PM
DSL PWR is on a distinguished road
While you are at it you should have a disable on the tool release on the panel. So far the ding on my table winking at me every time I use the machine has prevented me from pushing it again...
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 06-18-2009, 10:51 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
It's a hijack, but is somebody going to tell him?
(Pssst...there is a setting to turn that button off. It was the first thing the tech disabled on my mill during installation).
Greg
Old 06-18-2009, 11:26 AM
Originally Posted by Donkey Hotey View Post
...(Pssst...there is a setting to turn that button off...
Setting!, D**n, I looked in the Parameters but overlooked Settings so I missed being first.
Setting 76.
  #11   Ban this user!
Old 06-18-2009, 12:40 PM
setting 76 on the lathe is for foot pedal lockout.
I fixed it anyway. I took an old junk button from a different machine and pulled the hard plastic part off. A dab of super glue on the corner of it, and it fits perfect. It only sticks out 3/16".
  #12   Ban this user!
Old 06-18-2009, 02:27 PM
Originally Posted by Lathe Dog View Post
setting 76 on the lathe is for foot pedal lockout....
Sorry, we are guilty of a hijack; the Setting 76 comments were aimed at DSL PWR who was referring to a mill.
tool change position button on mill Randall Mach Mill 0 02-12-2009 02:30 PM
Tool Length Measurement - No Button On Panell avongil Mazak, Mitsubishi, Mazatrol 8 10-12-2008 04:19 PM
New Machine Build- EZ button? ericmattessich LinuxCNC (formerly EMC2) 15 04-29-2008 01:59 PM
Tool Release Button, Ken_Shea Haas Mills 3 08-04-2003 09:27 PM
so that is what that button does johnm Test Forum 0 03-26-2003 04:43 PM
