Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 06-13-2009, 12:31 PM
jz25180 is on a distinguished road
barfeed 300
I long part 7" I have to turn and put a knurl about .5 inch long. the bar is .5 dia.. then a chamfer at the end. I know there's a way but can figure it out . you can push the bar out half way out make the front then push the rest out. then do the end.
Old 06-13-2009, 12:42 PM
If that is all, knurl near one end then chamfer the other you can probably do it in one push.
Have stock protruding enough to do the chamfer, push out to stop, do knurl then part off, etc.
Old 06-13-2009, 04:47 PM
barfeed G105??
I have to bore the id where the knurl is at also about .5 in . Thats the only reason i have to knurl it first. The g codes is something like this g105 J.?? I think , not sure.
Old 06-13-2009, 05:07 PM
I don't use the Servo 300 so I cannot help you on that code.
For the part do the knurl and bore then push, chamfer and part-off. Doing two pushes per piece is going to increase your cycle time by quite a bit.
Old 06-15-2009, 09:39 PM
djr76's Avatar
djr76 is on a distinguished road
For an alternate push, it would be G105 Jx.xxx within your program.
Need Help!- Barfeed programming wganders G-Code Programing 15 06-24-2009 08:36 PM
Need Help!- Programming SMW barfeed on sqt-250 6thAxis Mazak, Mitsubishi, Mazatrol 1 08-07-2008 12:48 PM
LNS Barfeed Lazzer65 General Metal Working Machines 4 08-13-2006 05:22 AM
Barfeed Option pinguS Fanuc 3 07-27-2006 11:26 AM
servo 300 barfeed positiverake Haas Mills 12 02-14-2006 07:00 PM
