| Haas Lathes Discuss Haas lathe here! |
#13
![]() Anyway since I am getting the full enclosure and initially I'll be turning in the smaller size of the TL-2 envelop maybe the 3600rpm spindle is not a bad idea. It has the same size spindle bore and hp as the regular spindle but I think the 3600rpm spindle is even less popular than the enclosure. How come? Does the 3600rpm spindle have less torque than the 2000 rpm spindle? |
#14
![]() I just checked; the 8" is rated for 3100 rpm max and the 10" for 2700 rpm.
#15
![]() The enclosure does keep you cleaner and dryer and you don't get a face full of chips. One possibility for the 3600 rpm not being popular is that I think (could be wrong on this) that it needs 3 phase power for the larger motor. This does limit installation flexibility.
#16
| Higher RPM`s are great but not so sweet how it seems , on our SL-20 (10" chunk ) we had always trouble to turn small parts above 2800 RPM because the parts were always pushed by the tool into spindle , Higher RPM`s are loosing the pressure on the part , therefore we changed into collets , now we can turn at maximum speed without worry ( up to 65mm bar ). |
#17
| I cannot resist the temptaion to indulge is some alliteration and say the Polish person's point is very pertinent. (pit202 I apologise if you have to find a dictionary for pertinent. )My experience with manual chucks is that they do not lose grip as much at high rpm and I always figured this is because they tighten up mechanically. Hydraulic chucks are really bad and I find it funny how a chuck can be rated for several thousand rpm but it is not useable because the grip is lost.
#19
| Vern; I am sure you are expecting this so I will not dissappoint: Alliteration is a literary or rhetorical stylistic device that consists in repeating the same consonant sound at the beginning of several words in close succession. An example is the Mother Goose tongue-twister, "Peter Piper picked a peck of pickled peppers …".
#21
| I got Milton's email Haas_Apps and Milton's reply to my questions is as follows, The 3500 RPM spindle is only a disadvantage if your work is mostly large and heavy. You have a wide range of work and therefore the wise choice to make is the 3500 RPM spindle mainly because you need the speed for all your small work and still some descent power for large work. The figures below will give you an idea of what I mean.Anyway, thanks again for everyone's input. |
| Newbie- Small Parts | Deadwood | Autodesk Software (Autocad, Inventor etc) | 1 | 02-09-2009 10:07 PM |
| Need A Quote- RFQ - Small job 2 parts only | jjjtttggg | Employment Opportunity | 5 | 06-09-2008 11:45 AM |
| small parts | inpro | Machine Created Art | 6 | 01-26-2007 05:52 AM |
| RFQ small parts needed | CNC Darren | Employment Opportunity | 6 | 02-23-2005 10:49 AM |
| RFQ small parts | impact | Employment Opportunity | 7 | 12-29-2004 05:06 PM |
