Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 05-29-2009, 05:17 PM
masonbcaldwell4's Avatar
masonbcaldwell4 is on a distinguished road
Mill to lathe does not compute!
I'm unfamiliar with setting offsets on our SL-30, but maybe I'm just a tard.... I'm machining a .125 wide x .083 deep face groove with 1/32 radii at the bottom corners, but forget that for now... my grooving tip is .094... I touch it to the probe, Z works fine, but touching the top or bottom of the probe, no matter, my X never ends up right. probe is properly set up, but the tool nose identifier is where I think my problem may be... I've tried using 2, 3, and even 7, touching the top of the probe then subtracting half the width... please enlighten me, oh enlightened ones... lol I'll probably be asking again when it comes to those radii, but I hope to get enough of the basic idea through this... many thanks
Mason
No, really, just my .002"
Old 05-30-2009, 09:22 AM
djr76's Avatar
djr76 is on a distinguished road
Depending on which side of the probe you touch off in the X axis, thats the corner of the insert you program from in X (diameter) and pick the direction accordingly. If you are putting a radius or chamfer on the opposite side from the programmed tip, you just add or subtract (depending on direction of axis) the insert thickness in your programming.
Old 05-30-2009, 10:13 AM
DJR,
That's kinda what I figured, but I tried it with both sides and it was off with both... for instance, I touch with the corner that will be at the outside of the groove ( that dia. is supposed to be .688 ) then tell it to go to X0.688, plunge it in, say, .03 in Z, back it off and measure, and the groove measures 0.720ish. that is using "2" in the tool page, but that roughly 40 thou difference is roughly half the width of the tip... so I'm a bit stumped. like I said, this job is my intro to cnc lathes, so I'm probably making some moron mistake, but I appreciate the help all the same.
Old 05-30-2009, 02:49 PM
djr76's Avatar
Did you input in the tool tip radius in the offsets page? and are you using G41/42 correctly? It shouldn't act any different then say a trigon insert on a i.d. bore path. So in your case, it would be the left hand direction, (2) I believe, using a G41 Tool Nose Compensation Left (X,Z,U,W), and a .xxxx (radius of tool corners) tool tip radius in your offsets page.
Old 05-30-2009, 07:20 PM
Havn't even gotten that far... touch off the tip, then in MDI, put in:
T1010 G54 G0 X.664 Z.1 M3 S250
M8
G1 Z-.03 F.002
Z.01
G0 X10. Z10. M5
M9
Gives me a .720ish groove....
Old 05-31-2009, 01:39 AM
djr76's Avatar
does an o.d. or i.d. profiling tools represent the same problems?
Old 05-31-2009, 02:46 AM
Superman's Avatar
Superman is on a distinguished road
Where does the tool sit if you punch in X0. Z0.01 with compensation ON for that tool ?
Old 05-31-2009, 10:19 PM
Slightly on the X positive side, but I can't seem to figure out exactly how much.
DJR,
Unfortunately, I'm unsure. this is the first time I've done anything with this machine, period. I'm familiar with CNC mills, but this is the first CNC Lathe I've touched. I'm almost tempted to do it conventionally, even tho there are several pcs. to do.
Mason
Old 06-03-2009, 08:53 PM
djr76's Avatar
its very basic man, X is diameter and Z is length, its just like setting a G41 or G42 in the mill, the direction of the tool on a lathe is identical to the direction relative to mills.
Should I get a mill or a lathe? (Turning with a mill?) JMcDonald General Metal Working Machines 6 11-02-2008 11:02 PM
New Machine Build- My CNC mill with mini lathe performing CNC lathe operations ryansuperbee General Metal Working Machines 7 08-20-2008 02:06 AM
CNC Mill --> CNC Lathe. cnczoner General Metal Working Machines 3 03-18-2008 08:58 PM
CNC Lathe on a mill - what do I need? digits Benchtop Machines 35 06-02-2007 07:12 PM
Using a Mill as a Lathe? Chris64 General Metalwork Discussion 20 10-07-2006 03:48 PM
