| Haas Lathes Discuss Haas lathe here! |
Hey Guys, I have a SL-10 question. I have been running a Hardinge with Fanuc controls for about 2.5 years now and we just purchased a Haas SL-10 Lathe. On the fanuc controls i use a subroutine program for a safe index point for each tool change. Here is what the code looks like... O0001 G0G40G97G98G80 T0 X#501Z#502 M99 Pretty simple, at the begining of the program the i'm running i put in these values #501 = 6.0 #502 = 6.0 M98P1 This makes the turrent go to that location before making a tool change. I can't get my haas to work with this programming. I'm sure that I'm doing some thing wrong. Any help would be greatly appriciated. Thanks Josh |
| Ok I check and no Marco are not enabled. I will have to call Hass tomorrow morning and find out how much to turn it on. Next question....Here is the program that I am currently running. I keep getting a z axis over travel when the program is completely done and i hit cycle start for the begining of the next program..... O01122 (--------------------------------) (N1 - 80 DEG TURNING TOOL) (N2 - CENTER DRILL) (N3 - 12.0mm DRILL) (--------------------------------) G54 G00 X6. Z8. N1 G54 G00 X6. Z8. T101 S1200 M03 G00 X1.3 Z0. G50 S2500 G96 S500 / M08 G99 G01 X-0.05 F0.006 G00 Z0.001 X1. G01 X1.252 K-0.05 Z-0.25 G00 X1.4 G00 X6. Z8. N2 G54 G00 X6. Z8. T1010 G97 S1200 M03 G00 X0. Z0.2 M08 G99 G01 Z-0.3 F0.0015 G00 Z0.2 G00 X6. Z8. N3 G54 G00 X6. Z8. T707 G97 S750 M03 G00 X0. Z0.2 M08 G99 G83 Z-2.6 Q0.1 R0.2 F0.003 G80 G00 Z0.2 G54 G00 X6. Z2.5 M30 |
| sorry, I can not simulate that ( I have metrics ) - but you have the place to move into Z8 ? I had a very similar problem , but I uses W... , same effect after running the whole simulation the next run was Z overtravel , for me worked to change the W into G0 Z... but I don`t see W in your code, maybe it is an another haas bug in software. Peter |
__________________ Greg |
#10
| Josh, I don't use this command myself, but our Haas Rep. suggested it to us. It is a G53 command. Way I remember it working is, you select a safe point that all tools will clear when indexing, and designate that as your G53, then in your programming you command a G53 before you do a tool index. Like I say, I've never put this to use , so get the first hand from the Machine Manual for the full procedure. regards Paul |
#11
| Actually, that's a very good suggestion. I also use G53 for all of my toolchange locations. It's in machine coordinates and it's non-modal (meaning: it goes right back to the current work offset after you use it). G53 G00 X-2. Z-5. Don't forget to go back to G01 after using the rapid.
__________________ Greg Last edited by Donkey Hotey; 05-27-2009 at 01:53 AM. |
#12
| The rapids on the SL10 are so fast and the machine is so small you might just as well send it home for a tool change; G53 G00 Z0.0 I would take care using Greg's example because Z-13.0 puts you awful darn close to the chuck on the SL10.
| Your CAD Program? | Dolphin USA | Polls | 98 | 02-07-2012 11:28 PM |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 09:19 PM |
| Mazatrol Program into a G Code Program | fuzzman | Mazak, Mitsubishi, Mazatrol | 14 | 02-08-2010 04:55 PM |
| Program Restart in mid program? | Donkey Hotey | Haas Lathes | 16 | 03-18-2008 03:19 PM |
| Anyone got any basic examples of a program using a subroutine/program? | Darc | CamSoft Products | 11 | 10-09-2005 12:45 AM |
