Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
  #25   Ban this user!
Old 06-02-2009, 08:15 AM
Josh-PTP is on a distinguished road
Geof,
Took out the W0.005 and cut another part. Still did it?? Any other suggestions. I am using the same 55 Deg tool for the roughing and finishing.
Josh
  #26   Ban this user!
Old 06-02-2009, 09:17 AM
Are you in a panic for this?
The reason I ask is that I can run it through my Simulator or even on my TL2 but not for a few hours. First order of the day is mixing a bunch of concrete for a statue base I am making. And if I am still capable of moving after that...then I can fire up the machines.
  #27   Ban this user!
Old 06-02-2009, 09:20 AM
Well, I am tring to get it setup today for a little bit of a production run. I have contacted my Haas HFO and they are working on it also for me. In the mean time I have changed the program and using my cam software to cut it. Just was wondering what I was doing wrong. Have fun with that Concrete though. It's a hot one here today!!!
If you get a chance to work on it later and find something out please let me know.
Josh
  #28   Ban this user!
Old 06-02-2009, 01:44 PM
Two problems, one your's one Haas's, but first a question; do you use Graphics to check your programs, especially by zooming in to see the detail of the toolpath? I suspect you do not because you would probably have found both.
I renumbered your program so I could refer to line numbers.
Line N19 which is supposed to give a chamfer does not chamfer during the G71 the tool just plunges straight in, but it does the chamfer during the final run through the P, Q block and during the G70. I do not use the automatic chamfering so I would never get something like this.
Line 21 which does the radius should be a negative value, your radius goes the wrong way.
O00000
N1
N2 G53 G00 X0 Z0
N3 T202
N4 S1200 M03
N5 G00 X1.3 Z0.
N6 G50 S3500
N7 G96 S250 / M08
N8 G99
N9 G01 X-0.05 F0.006
N10 G00 Z0.2
N11 X1.3
N12 G71 P13 Q27 U0.04 W0.005 D0.04 F0.008
N13 G00 X0.45 Z0.01
N14 G01 Z0.001
N15 X0.51 R-0.03
N16 Z-0.375
N17 X0.62 K-0.05
N18 Z-1.25
N19 X0.506 A210. Chamfer is ignored by G71
N20 Z-1.575 R0.05
N21 X0.629 R0.015 R value should be -0.015
N22 Z-1.98
N23 X0.866 R-0.03
N24 Z-2.175
N25 X1.18 K-0.04
N26 Z-2.625
N27 X1.3
N28 G53 G00 X0 Z0
N29
N30
N31 G53 G00 X0 Z0
N32 T202
N33 G97 S1200 M03
N34 G00 X1.3 Z0.2
N35 G50 S3500
N36 G96 S300 / M08
N37 G99
N38 G70 P13 Q27 F0.004
N39 G00 X1.3
N40 Z-1.98
N41 G01 X0.609 F0.003
N42 G00 X1.3
N43 Z-2.175
N44 G01 X0.846
N45 G00 X1.3
N46 G53 G00 X0 Z0
N47 M30
Your CAD Program? Dolphin USA Polls 102 04-25-2012 11:25 AM
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
Program Restart in mid program? Donkey Hotey Haas Lathes 16 03-18-2008 02:19 PM
Anyone got any basic examples of a program using a subroutine/program? Darc CamSoft Products 11 10-08-2005 11:45 PM
