Originally Posted by teamjnz Hello fellow Haas users.
I am looking to get my first CNC lathe. I have been setting up and making CNC mill and lathe parts for years on both standard Fanuc and Haas controls for different employers. Now I am going to try it on my own.
I am looking at a 2000 SL20. It has the servo 300 bar feeder, toolsetter, parts catcher, tailstock and auger.
What kind of things should I be looking for to avoid buying a piece of junk? I know that most shops don't get rid of good running machines, they keep running them because they are making money.
Any hints of future problems would be appreciated. |
A few things you can check for are Ball Screw Noise in Rapid Moves, Rotting Coolant Tanks, Spindle Noise. I mean bad Noise like grinding, thumping, anything not smooth. Cut a shaft with Hard Jaws of about 2 inch in diameter to check the Taper over at least 8 to 12 inches out of the chuck. Low RPM of coarse. The Taper should be no more than .0003 for a .03 cut on the side. If more, it's probably been whacked.
Just a few off the top of my head.
