| Haas Lathes Discuss Haas lathe here! |
We have a TL-1 and we have been trying to create a program with a radius on the end...like a pawn in chess. We have failed everytime trying to create a profile. We are trying to do it using the custom profiler generator (or whatever it is caalled) We can't seem to get anything to work other than simple parts. Anything with an undercut or a radius, like a 3/4 ball fails miserably. |
| We've found similar limitations. The lathe profiling software, unlike the mill, doesn't give you the ability to create CW or CCW arcs, just rapid moves or lines. You CAN, however, fillet 2 lines. Try creating the 3/4 ball shape as a square shape (3 lines), the length of the 2nd line (along Z axis) would be 3/4, then fillet the 2 intersections using something just less than a 3/8 rad. This won't give you a true sphere, but close to it. I think the remaining lines after filleting have to be at least as long as the tool nose rad. Only way to create a true spherical shape (so far) is in CAD/CAM, not on the control. I'm hopeful Haas is working to improve the profiling software, it IS fairly new. Ed |
This is not entirely correct. Programming a sphere is relatively simple and is possible using G71 or if you want to push a few keys simply by direct coding all the moves.
| O0001 G0G40G80G97G99 S1500M3 T0101M8 G0X1.125Z.1 G71P10Q20U.005W.002D.1 N10G42G0X0. G1Z0.F.005 G3X1.Z-.5R.5 G1Z-.525 N20G40X1.125 Z1.M9 G28U0W0 M30 % I did not program with SFPM but you get the idea. On the Geometry page there will be a Tool Tip Designation, Nose Radius Designation, and Tool Location from Home to the Work Shift. All these are needed to have a trouble free Zero Alarm run.
| Very often we use a mix of CAM, IPS & hand G code on our TL-2. While CAM is great and IPS is good, though limited, you're right to encourage folks to learn & understand G code. No limits. Ed |
Are you getting some kind of error? Is your final move point at a larger X than your start point? That's very important because it establishes which quadrant the lathe is cutting in. If that doesn't make sense, look in your manual at the different canned roughing/finishing cycles. This still kicks my butt with certain profiles--but I'm learning.
__________________ Greg |
| The machine is brand new with the updated software. We got it about 4 months ago. I have tried entering a radius into the column all the way to the right and it never shows the proper profile that we are trying to create. And yes, I amaware it can be G coded and I can do that, as well as using mastercam to do it...but I was trying to use the IPS and it has failed for certain profiles |
| I just looked at my machine and for the life of me, I can't figure out how to get that first column to change to Arc. You're supposed to be able to change that to 2 or 3 (arc). Mine will only do 1 or 4. I must be doing something wrong with the lead-in moves or something. I'll look at it again later.
| Ed |
#10
| I noticed that in that software it asks for a radius if you want to add one. This radius is supposed to start at the end of the previous line according to the prompt. I can't get it to work and my boss is pretty mad about it. I like Haas. I enjoy running their machines but I don't think my boss will buy another one because he sees to many problems with it. |
#11
| It's all coming back to me now. ![]() Yes, the lathe IPS can do the G01 method with an optional Radius value (G01 programmed with specified corner rounding) but it can't do non-tangent arcs like the head of a pawn. I wonder why they left the 'arc' prompts in there? I've been over this before and those prompts confused me yet again.
| Please help! Z-axis transistor keeps failing when I turn spindle on | jderou | Bridgeport and Hardinge Mills | 1 | 03-27-2009 08:09 AM |
| Need Help!- profiling | chaz6966 | BobCad-Cam | 1 | 02-21-2009 07:15 PM |
| profiling | camtd | GibbsCAM | 1 | 02-24-2008 09:17 PM |
| Is our education system failing us in the USA? | CJL5585 | CNCzone Club House | 42 | 02-26-2007 10:06 AM |
| Profiling | dneisler | SprutCAM | 31 | 09-29-2006 06:45 AM |
