Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 04-03-2009, 09:35 PM
parktoshi is on a distinguished road
How to make 2"1/2 NPT left hand threading on Haas SL-20
Hi everyone,
Can someone help me? How I can make the 2"1/2 NPT left hand thread. What's G code I use for.
Thank you for your help.
Old 04-03-2009, 10:39 PM
G76 or G92 with a value for I to give the taper. You run the spindle in reverse and have the cutter upside down.
If you don't have a manual go to this link and your can download a pdf file.
http://www.haascnc.com/custserv_updates.asp#manualupd
Old 04-08-2009, 05:27 PM
prupp is on a distinguished road
i learned the hardway to be sure the I (taper) is correct as far as negative or positive, i think an id thread has a positive I number, just shift your tool out and run air passes to confirm. do you need help as far as calculating the taper and code?
Newbie- Left Hand Threads LESchwartz General Metal Working Machines 4 02-18-2008 07:03 PM
Why do you use your left hand ImanCarrot General Metalwork Discussion 24 10-15-2007 06:14 AM
Left hand screwcutting rcflyer Mini Lathe 10 11-07-2006 04:23 PM
I need 2 7/16"-13 left-hand-threaded nuts kdoney Employment Opportunity 8 02-11-2006 04:07 PM
coverting from Right-hand to left-hand coordinate system eltonr General CAM Discussion 6 10-14-2004 08:40 PM
