| Haas Lathes Discuss Haas lathe here! |
I've called Haas and no one will call me back. I just need and extra 1/2" of x travel to clear a large dia. part.I know removing the limit switch is a not recommended.Anyone have any sucess getting more X travel without harming the machine. Thanks, Jeff |
| I think you would be taking a risk, 1/2" is a lot and you mind finish up bending way covers and things like that even if the linear guids and ballscrew had extra travel.
| I had to get some more X out of my sl-20 a while back. Max 10.00 x and i needed 10.75. After a day of thinking...I went outside the box and did this.. I installed a boring bar backwards (upside down) in one of my slots. I programed the toolpath running the lathe in reverse....(rotation that is) This gave me about 2 inches in x ...more than enuff... My 2 cents anyway... Grats on getting your solution to work. |
| Sure,but let it be know that:I DON'T RECOMMEND THIS TO ANYONE THAT DOESN'T KNOW WHAT THEY ARE DOING !!! I removed the x axis limit switch and slotted the botom hole down .250 In .001,I moved the x axis up(be careful not to run the slide above the slides. I then re-installed the limit switch,slide the limit switch until it lights up(then causing the machine to call that home) The way you can check this is to put the machine in 5 percent rapid and see if it works.I was told my Haas sevice that the worst that could happen was it'll overtravel causing the servo's to shut off. I gained .4714 x axis travel,thus solving my problem. |
| Extra .500" Y Travel on a Taig | JoeDawg | Taig Mills & Lathes | 3 | 01-10-2009 04:56 PM |
| X3 extended y-axis travel (7.75" vs 5.75") ? | nullbert | Benchtop Machines | 7 | 10-05-2008 12:28 PM |
| "Actual" max Z axis travel? | Otter1 | Tormach PCNC | 31 | 09-15-2008 05:12 PM |
| Smaller CNC ~18"X18" XY with more than 5" Z travel? | SkyG | Commercial CNC Wood Routers | 1 | 12-18-2007 12:57 PM |
| Easy Q: Is 25" travel ballscrew enough for 24" bed? | NC_jimbo | Linear and Rotary Motion | 8 | 03-16-2007 03:47 PM |
