Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 02-27-2009, 08:33 AM
Fairlane6t9 is on a distinguished road
Chuck PSI
Hi all. We have a HAAS sl10 lathe with the hydraulic 3jaw chuck. Does anyone have an idea what psi setting would be good to hold 2.5" diameter machinable wax? I have it set at 100 psi now and it basically cracks the wax all the way through.
Old 02-27-2009, 09:35 AM
I think you have an unsolvable problem; if you go much below 100 psi the chuck stops moving I have found.
I am guessing you are using a three jaw so the area of contact is small?
Either machine up some pie jaws for almost full 360 degree contact or make a split sleeve to grip it in.
Old 02-27-2009, 11:10 AM
Chuck
Yes, it is a 3 jaw. The split sleeve sounds like a pretty good idea. I think we'll try that.
Problem- chuck run out InfinitySteel General Metal Working Machines 1 12-28-2008 08:31 AM
Chuck nmcdairmant General Business Practices and Pricing 0 09-08-2008 10:18 AM
2 Jaw Chuck HBFixedGear General Metalwork Discussion 0 10-05-2007 03:14 PM
Q: Need 5C Chuck Deviant Mini Lathe 1 04-23-2007 03:15 PM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 01:20 AM
