Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 02-24-2009, 03:48 PM
theatrewizard is on a distinguished road
coolant pump/fuse box
My coolant pump just lost power in the middle of a run. Levels are all good, and there is no voltage to the twistlock outlet the pump plugs into. Does anyone know where to look for a fuse box?
thanks ahead of time
Chris
Old 02-24-2009, 03:49 PM
Sorry,, Haas SL 30 lathe (with the dead pump.....)
Chris
Old 02-24-2009, 04:20 PM
Go into the control cabinet at the back of the machine and you will see a breaker labelled coolant pump; this has probably opened.
There are a few possible reasons this has happened:
1: The centrifugal switch that cuts out the starting windings has failed; this is a weak spot on some of the motors. You can get replacement switches but right now I am not at the business so I cannot give you a link.
2: Some chips have jammed the impeller so the motor has stalled and overloaded.
3: You might be one of the unlucky ones who got a machine with a coolant pump motor from a different supplier than Haas had been using for years, if your machine was new in 2007 or thereabouts this could be the problem. The fix to this is get hold of your HFO they should have a service bulletin that describes installing a larger capacity breaker or something like that.
325 Coolant Pump TurtleRacing Tree 4 04-02-2012 01:51 PM
Need Help!- SYIL X3 COOLANT FUSE RMDMARINE Syil Products 3 09-02-2008 01:12 AM
Need Help!- coolant pump JACKSMACHINE Fadal 0 05-22-2008 03:13 PM
TM2 Coolant pump Peter Gibbs Haas Mills 4 05-03-2008 12:11 PM
Coolant Pump Smackre Mechanical Calculations/Engineering Design 7 06-29-2007 01:16 PM
