Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 02-19-2009, 08:23 AM
Fairlane6t9 is on a distinguished road
Smile Threading tool settings
I have a newbie question concerning setting the threading tool on an SL10. What's the best way to set the z offset when touching the threading tool off? I'm using a standard 60 degree threading insert, but am curious as how to set the Z so that I get the correct thread length. Any ideas? Thanks in advance!!
Old 02-19-2009, 09:10 AM
chucker's Avatar
chucker is on a distinguished road
If I am threading up to a shoulder I always touch off the leading edge of the insert so I dont hit the shoulder then use mt tool length to ajust it as close to the sholder as I can if I am not threading up to a shoulder then I set it at the point. Although it depends if your programmer has took this in account when he wrote the program.
Old 02-19-2009, 09:18 AM
Same approach as chucker; I like to know the position of the furthest point on the tool because that is what hits things. I find the distance from the end of the insert to the center of the tip is about equal to (maximum) pitch the insert is good for; in other words with a full profile insert that is the pitch but on a non topping insert it is the pitch at the top of the range the insert is used for.
Mazatrol M2 Tool settings help nlh Mazak, Mitsubishi, Mazatrol 3 02-06-2008 02:10 PM
TOOL SETTINGS FOR MY FANUC 18M VMC PICMAN Fanuc 1 12-02-2007 05:59 AM
Internal threading tool suggestions kdoney Mini Lathe 5 03-02-2006 12:41 PM
ID Acme threading tool needed 2_jammer General Metalwork Discussion 2 04-18-2005 09:08 PM
Threading tool recomendation Toddjones Machine Problems, Solutions , Wireless DNC, serial port 4 02-18-2005 12:55 AM
