Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 02-11-2009, 02:42 PM
Tazzer is on a distinguished road
TL-2 Simple Questions
Well we just signed over a check to purchase a TL-2 and there were a couple basic questions I forgot to ask and I really don't want to deal with the sales guy again and was hoping if anyone can help out with these couple questions.
We purchased a TL-2 with:
Coolant Pump Kit
Manual Tailstock
12" Chuck
4 Station Turret
and Quick Change tool post.
First question is on installation, does the TL-2 need compressed air and if so what is it used for on the TL-2? Reason asking would a basing 5hp 50 gallon compressor work or should we plumb it to our be air dried compressor.
For those who have purchased the tailstock does it come with a dead center or live center?
This is the first time we have bought a lathe and a little anxios and want to make sure we have everything before the machien arrives.
Old 02-11-2009, 03:10 PM
axis is on a distinguished road
no dead or live center,if you have an air dryer every machine should get air from there i dont think your machine will need it but you will need an air gun,why you need a 12" chuck a 10" should be more then enuff. and call the sales man bug the hell out of him thats what he is paid for. earplugs saftey glasses and a rain jacket are also needed.
Old 02-11-2009, 03:13 PM
Tailstock option does not include any centers alive or dead.
Clean, dry air is needed for the tool turret.
12" chuck is overkill and is going to slow down the spindle acceleration.
Old 02-11-2009, 03:33 PM
Thanks for the quick reply guys. We needed the 12" for one of the discs/parts we will be running!!
By any chance do you guys know what morse taper the tailstock uses???
Old 02-11-2009, 05:34 PM
I think tailstock taper is #4.
Regarding needing a 12" chuck for a big disc if you get something like a Bison with removable top jaws you can make custom jaws to hold discs much larger than the chuck body. Adapting a smaller chuck with funky custom jaws means you do not have the frustration of long start and stop times with a machine running small parts at higher speeds with a big chuck.
Old 02-11-2009, 11:37 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
I'm pretty sure that the tailstock is MT-5, not MT-4. Geof probably just mistyped because he is not known to make such basic mistakes.
The machine itself doesn't use any air (unless its different than the TL-1). I also agree: the 12" chuck is totally overkill.
Greg
Old 02-12-2009, 09:04 AM
He's probably correct, but I do know it is big, ridiculously so because the machine would never drive the largest size of drill that could be fitted in the taper.
Old 02-12-2009, 05:57 PM
I'm pretty sure that the tailstock is MT-5, not MT-4......
Oh ye of little faith; I decided to look it up. See below copied right from the Haas specs:
"Manual tailstock for TL-2 includes platform with 48" travel (1219mm) & quill section with MT4 & locking handle for manual thrust."
Old 02-12-2009, 06:18 PM
behindpropeller is on a distinguished road
We also got the upgraded pump with our tm-2.
If I were to buy another one like it I would just upgrade the pump myself and put the $$ into tooling.
I would have also made them throw in some class time.
Tim
Old 02-12-2009, 08:07 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Upgraded Pump
Hi Tim,
Does the TM-2 have an enclosure? I don't think so??? That upgraded pump really puts out a good coolant spray and will give you a bath of coolant if you don't have some type of enclosure. The standard 5 gallon pump system is a JOKE.
John
  #11   Ban this user!
Old 02-12-2009, 11:55 PM
You win, Geof. I was thinking of the TL-1 spindle (A5). I made that mistake once before, when I ordered a rotating tailstock chuck.
Greg
  #12   Ban this user!
Old 02-13-2009, 12:01 AM
I am not much better...I ordered a chuck and got the spindle specification wrong; needless to say it did not fit.
A couple more simple questions for a CNC builder Danno General CNC (Mill and Lathe) Control Software (NC) 3 12-11-2008 11:27 AM
Please Help!! Simple 3-D part not so simple for me eaglegage Mastercam 16 05-15-2008 10:00 AM
Simple Questions pzzamakr1980 Mastercam 11 03-12-2008 08:54 AM
Simple questions. Dr Honda Gecko Drives 2 09-10-2007 10:51 PM
Simple Question Simple Answer ? p3t3rv Stepper Motors and Drives 6 02-16-2006 09:00 AM
