Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 01-20-2009, 12:48 PM
Adam77 is on a distinguished road
Help! running inconel
Hello,
I am running inconel on a Haas Lathe CNC machine and I am having trouble with the speed rate and RPM to cut spline head inconel. At what standard speed setting should I try to set the speed rate and RPM? What inserts?
Thanks in advance for all your help!
Adam
Old 01-21-2009, 06:26 PM
WallyL7's Avatar
WallyL7 is on a distinguished road
Do you have a local tool guy? You should be able to get them to give you some inserts to try (and buy if you like 'em). It's been a while since I've cut inconel, but it isn't any big deal.
Probably want to go with a TiCN coating.
Your tool guy will give you speeds and feeds - or check with the manufacturer of the insert you end up with. They always have application guys.
Old 01-21-2009, 09:04 PM
BYTHEBOOKBOB's Avatar
BYTHEBOOKBOB is on a distinguished road
We machine X750, 600 and 909 Inconel quite often. We use I believe that we use Sandvik 1525 inserts for the material and get beautiful results. Give your Sandvik rep a call and I'm sure they will set you up.
Good luck,
Bythebookbob
Old 02-07-2009, 03:55 PM
leepez is on a distinguished road
We use Iscar CNMG's IC907 grade for roughing 1.2mm rad, not sure if they are the best but we do get a good deal price wise.
Sumitomo EH10Z's for finishing.
Arno are good too, cant remember the grade off the top of my head but will find out.
Old 02-07-2009, 04:00 PM
Good luck,
Bythebookbob
Hi Bob,
Would that be a CNMG insert? and what profile rad does that insert use?
Thanks,
Lee
Old 02-07-2009, 06:51 PM
williams480 is on a distinguished road
Chipformer is crucial too.
Iscar has a new Grade IC807, look for a CNMG 432 TF IC807 for medium DOC.
1.0-2.5mm DOC & .15 - .25 mm/rev.
Need A Quote- inconel 710 jaimeoro Machinist Feedback 7 03-24-2009 01:25 AM
cutting inconel 718 stsrvanvliet General Metalwork Discussion 12 03-18-2009 09:08 PM
Need Help!- Drilling Inconel mmiranda General Metalwork Discussion 8 01-16-2009 02:58 PM
inconel positiverake1 General Metalwork Discussion 0 10-15-2007 11:27 PM
cutting inconel dry stsrvanvliet General Metalwork Discussion 3 11-14-2006 07:01 PM
