Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 01-07-2009, 07:26 PM
vicstransam's Avatar
vicstransam is on a distinguished road
HAAS debug mode
For anyone wanting to know,
This is how we get into debug mode on a TL25 lathe with version 6 something software.
To get into debug mode go to SETTING 7 "PARAMETER LOCK" and set to OFF.
Go to ALARM page and type DEBUG and press "write" button.
You are now in DEBUG mode. To exit debug mode, type DEBUG once more in ALARM page.
I don't think it matters what you were in when going to ALARM page, such as EDIT or MDI or JOG.
PI R ROUND
Old 01-08-2009, 09:06 PM
MikeOD is on a distinguished road
You really shouldn't be messing around in Debug if you don't know what you're doing (ie trained at the factory) as you can cause some serious damage to the machine almost instantly in debug just by changing something by accident.
Old 01-09-2009, 11:28 AM
I certainly don't recommend changing anything, but it could be useful to some to help diagnose a problem by just flipping through the wealth of info. If you don't need it, don't do it.
PI R ROUND
Old 01-10-2009, 12:05 PM
Edster is on a distinguished road
I use it occasionally to check the machine hours. The other timers can be reset. I never messed anything up, but I was being careful
Old 06-30-2011, 11:51 AM
*Registered User*
Travis P. is on a distinguished road
Debug to check alterations in machine?
Hello, I have a Haas TM-2 that has the key lock option on the side already. However we would like to explore other options too. I would like to see if there was a option in debug mode or such that keeps track of any personnel altering parameters or programs and such. The memory lock is way to simple for unathorized personel to figure out. Also is there a way to find out when a program was last eddited and added into the memory as a way to trace the time to an individual?
Thanks!
Old 07-01-2011, 10:47 AM
djr76's Avatar
djr76 is on a distinguished road
Sometimes is necessary, like when you knock your box out and need to re-adjust centerline.
PICStep V4 (or how to not have to debug your own BOB but use someone elses!) Garfield2 PicStep Controllers 2 10-08-2011 09:43 AM
What is - Torque Mode? Position Mode? Speed/Velocity Mode? sunmix Servo Motors and Drives 25 10-26-2008 03:53 AM
Debug Fido57 Haas Mills 2 02-24-2008 07:15 AM
HAAS LATHE Graphics Simulation MODE DEAN Haas Lathes 4 11-18-2007 09:45 PM
Haas Graphics Mode - changing display speed? pdoherty Haas Mills 15 04-09-2007 08:57 PM
