Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 12-18-2008, 05:59 PM
69ss396 is on a distinguished road
SL10
our sl10 just started leaking air really bad when you try to make a tool change and then it alarms out. Any ideas
Old 12-18-2008, 06:06 PM
Sounds like the airline supplying the air cylinder that unlocks the turret has started leaking. I think the alarm will either be low air pressure or turret unclamp fault.
Old 12-20-2008, 06:34 AM
HAASboi's Avatar
HAASboi is on a distinguished road
i think your air compressor is not supplying adequate air ..it happened this in our sl20 when i tool change check your air compressor pressure
Old 12-21-2008, 12:52 AM
shawncnelson is on a distinguished road
My brand new SL-10 had a similar problem. At a tool change a massive air leak could be heard from near the headstock. It turned out to be a faulty air regulator, the one that your supply air is connected to. They sent the part over night and had a tech install it the next day.
http://www.1dropdesign.com
Old 12-22-2008, 07:28 AM
We found tht the air line going to the turret was hitting the x axis drive motor when the turret indexed and it broke the line loose. The tech came in and changed out the fitting and reclocked the line so it would not hit the drive motor and we are up and running again.
Thanks everyone
??'s on SL10 tooling JDenyer232 Haas Lathes 8 07-15-2008 01:22 PM
What's next for the SL10? PBMW Haas Lathes 12 05-22-2008 05:21 PM
The latest my SL10 PBMW Haas Lathes 15 02-03-2008 07:16 PM
SL10 dies yet again PBMW Haas Lathes 24 12-17-2007 09:19 AM
SL10 dies again PBMW Haas Mills 1 05-15-2007 03:45 PM
