| Haas Lathes Discuss Haas lathe here! |
Hello to everyone. Just started with new company, they manually programmed some c-axis drilling etc. Also new to mastercamx. Not much experience with lathes. Should this program be close to working (don't want it on machine yet.) Any input would be appriciated. thanks-harry. G20 (TOOL - 7 OFFSET - 0) (7/32 DRILL) G28 U0. W0. G50 X10. Z10. G0 T0700 M23 G0 X9.5 Z-2.3 C90. G97 S1222 M51 G81 X.4 R4.5 F4.11 C30. C-30. C-90. C-150. C-210. G80 G28 U0. W0. H0. M55 T0700 M30 |
| Harry, Maybe I can help you out. First, lets dissect your program and see what you have .... G20 --- Default command. Okay to have here but not absolutely needed. (TOOL - 7 OFFSET - 0) --- Okay. Tool# and Offset # description (7/32 DRILL) --- Okay. Tool description G28 U0. W0. --- Don't need U0. W0. with G28 G50 X10. Z10. --- Bad line. G50 is Spindle Speed MAX RPM Limit ie; G50 S3100 G0 T0700 --- Bad Line. M23 --- bad Line. M23 is Angle Out on threading "ON" G0 X9.5 Z-2.3 --- Okay. Rapid move in X and Z to your start point ? C90. --- Bad line. Can't run C- Axis without first engaging C-Axis with M154 G97 S1222 M51 --- BAD line. 1) DO NOT turn spindle (G97 S1222) when cross drilling & 2) M51 is Optional User M Code Set G81 X.4 R4.5 F4.11 --- I don't believe you can use a G81 drill cycle with the live tool C30. --- Okay. Rotate to 30 degrees... C-30. --- ??? Rotate to -30 degrees C-90. --- ??? Rotate to -90 degrees C-150. --- ??? Rotate to -150 degrees C-210. --- ??? Rotate to -210 degrees G80 --- Not sure. If G81 is usable with live tool, then okay. G28 U0. W0. H0. M55 --- Bad line. Don't need H0. and M55 is another Optional User M Code Set T0700 --- Potentially bad line. "00" after T07 cancel tool 7's offset. This can get you in BAD trouble if you're not careful. M30 --- Okay. Reset program and return to beginning. So..... we need to know a few things. 1) What kind of material are you working with ? 2) What is diameter of area being drilled ? 3) How deep are you drilling ? 4) Is hole blind or thru ? 5) Are the holes in specific relation to any other part features ? ie; Does hole #1 start xxx degrees off from a flat that is on the part ? Or are there simply 5 (?) holes equally spaced around the part ? I'll keep an eye on this post for your reply or you can email me. Best Regards, Steve |
G50 is also a command to set your coordinates I would recommend looking at the examples in the manual. |
| Haas_Apps, I stand corrected.... My only defense is that 1) I have never had need to use G50 for anything other than spindle speed clamping 2) When I was replying to the original post, I referred to my copy of Haas' Machinists CNC Reference Guide for G50 and M23 and it says only that G50 is Spindle Speed Maximum Rpm Limit, and nothing about work coordinate setting... At any rate, thanks for the info. Will download latest Operators Manual from your site and read up on G50. |
| Drilling question .25 hole is not .25? why | Rich05 | General Metalwork Discussion | 33 | 07-12-2008 09:00 PM |
| Hole drilling help | stevehuckss396 | General Metalwork Discussion | 23 | 01-27-2008 01:15 AM |
| Drilling a .010 hole | CoolhandLuke | General Metal Working Machines | 7 | 03-25-2007 10:44 PM |
| Drilling a hole in a 3D model | mayhugh1 | SprutCAM | 5 | 10-25-2006 11:51 AM |
| Deep hole drilling on OKK | eddie | G-Code Programing | 1 | 09-21-2005 06:55 PM |
