I am trying to find out if anyone can shed some light on my problem. While running my lathe (Haas SL30) i had an extra long part i needed to make. Soi drew the part loaded it on the machine and where i input the modal code, M21 for the tail stock to move forward, it went to where i had it set but thats it. The machine just stayed on that line instead of contuinuing with the program. What am i doing wrong and how is the TS supposed to be set up cause im not sure if i did that right. I looked in the manual but it says nothing on the TS operations, it just talks about the codes used and thats it. PLease help if you can
P/K
LinkBack URL
About LinkBacks
