Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 11-10-2008, 05:54 AM
SaxorLeoj is on a distinguished road
Haas SL-10 Parameter
Hi to all,
I have a problem with the Tool Indexing of our Haas SL-10
lathe machine. The tool position is not in the center of the
spindle on all the 12-index tool positions by about 5mm.
The index is controlled by a servo motor so we are trying to locate
and identify what is the parameter number for this adjustment.
We have no parameter list so please anyone who can help me with this
problem.. Thanks..
Old 11-10-2008, 03:29 PM
If you are off by 5mm when the turret is locked I do not think it is a parameter problem. It sounda like the machine has been crashed and the turret has moved on the locking plate. Near the center of the turret there is a circle of bolts that will probably have to be loosened so the turret can be moved into alignment and then re-tightened.
If you just change a parameter what might happen is the turret will stop without the locking dogs aligned and when it tries to lock something could get broken.
If you search through the threads in b oth the Haas Lathes and Haas Mills you will probably find something about re-aligning the turret. It has been mentioned before but I cannot remember when.
Old 11-25-2008, 08:45 AM
MikeOD is on a distinguished road
Yeah, thats not a parameter adjustment...your best bet is to ask your HFO to re-allign the machines turret. It can take some time to get it right.
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
HAAS Service HAAS Repair NY NJ CT PA serviceman Product Announcements & Manufacturer News 1 01-04-2008 03:27 PM
hardinge / haas indexer parameter 30 ? jim007 Bridgeport and Hardinge Mills 0 02-19-2007 03:13 PM
Haas 2 haas serial comunication? CNCgr Haas Mills 3 12-22-2006 12:07 PM
