| Haas Lathes Discuss Haas lathe here! |
yeah, just got a brand new SL-10 with the bar feeder. Does anyone else have one that leaks half of its paltry coolant supply all over the floor? I think it's coming from somewhere near the headstock/auger drive. The Haas tech came out, tightened some bolts, added some caulk and went away. It's no better.
__________________ http://www.1dropdesign.com |
| We did have one that did that, and it was at the auger drive, and it was necessary to caulk and tighten a few bolts. BUT first it was necessary to take off all the sheetmetal above the auger down under the headstock and clean all the coolant out to get at the bolts that needed tightening; the loose bolts were below the waterline when the machine was completely full of coolant. If your Haas tech did not all of this then maybe the wrong bolts were tightened.
| Leaking coolant reservoir | JTulley | Tormach PCNC | 5 | 08-03-2008 08:51 AM |
| fiberglass gas tank and leaking. | krymis | Composites, Exotic Metals etc | 6 | 07-28-2008 07:03 AM |
| Problem- Haas TM2 Leaking Coolant | Chris Swier | Haas Mills | 1 | 06-20-2008 09:57 PM |
| Problem- thru spindle coolant leaking | GARY DAVIS | Fadal | 4 | 03-25-2008 07:28 AM |
| Air/Hydraulic leaking problem?? | bherr | Bridgeport and Hardinge Mills | 1 | 06-19-2007 10:50 PM |
