| Haas Lathes Discuss Haas lathe here! |
Ok, So I know my tool offsets are set right because my haas tech set them during training a week or so ago. I haven't used it since. Although I just put in a 2" Diameter stock of Steel with a Rockwell hardness of 24. I want to turn this down to a Diameter of 1 1/4" with a .3" radius fillet. So I used IPS to generate the code that follws. However when I ran this code in settings graphics I get alarms. Here is the code that follows, the first alarm is generated at the G00 Z0.05, I changed this value to negative and even to Z-21.0 because I knew it wouldn't crasht here but I still get errors? What gives? Thanks Code: O00060 (OD TURN) T101 G54 G50 S800 G96 S650 M03 G00 X2.08 G00 Z0.05 G71 P101 Q102 U0 W0 D0.025 F0.01 N101 G00 X1.25 G01 X1.25 Z-2.312 G02 X1.226 Z-2.3 R-0.012 N102 G01 X2.08 Z-2.3 G00 X2.08 Z0.05 M30
__________________ -JWB --We Ain't Building Pianos (TCNJ Baja 2008) |
| Yeah I set my offset by going into work setup. I brought my tool up to just touching the face of my part and pressed Z face measure. But I still get that Z over travel error. Any other ideas on how I can turn this down?
| Hello,I don't know much about Haas TL-1 but try this below i know it's a 2 liner for the G71 and might not work on your machine but the rest should, you might have to change it back to a 1 liner for the G71. You need to have a home and safe index position in your program or it will index on the chuck! The G1 after the N101 line needs to have a feed rate as this will cause an alarm. Your G02 line was the wrong way see below. Hope this helps if not show drawing of what you are tring to do and we will take it from there... O00060 (OD TURN) *************** GOG4OX6.Z2.T0000 (THIS BIT SHOULD BY YOUR HOME & INDEX POSITION) (NEED TO CHANGE TO SUIT YOUR MACHINE AND REMOVE *) *************** G50 S800 T101 G96 S650 M03 X2.5Z.125 (RAPIDS TO START POSITION FROM SAFE INDEX) G71U.1R.01 G71 P101 Q102 U0.01W0.003 F0.01 N101 G00 X1.25 G01Z-2.3F.002 (NEEDS TO HAVE A FEED RATE HERE) G02 X1.274 Z-2.312 R-0.012 N102 G01 X2.08 *************** GOG4OX6.Z2.T0000 (THIS BIT SHOULD BY YOUR HOME & INDEX POSITION) (NEED TO CHANGE TO SUIT YOUR MACHINE AND REMOVE *) *************** M01 M30 |
| Chucker, Hey thanks for the help. If I run the program without Single Block in Settings Graphics I get the following errors: 318 Z Over Travel 611 G71/G72 Type I Alarm (This has to do with the type of roughing apparently) 603 Non MOnotonous PQ Blocks in Z I really need to get this Piece Turned down before 5 so I can impress my boss. thanks.
| Gripper, No that unfortunately didn't work. It ave me the same Z over travel Error and oddly where you had it rapiding it gave a multiple codes error. Even after I added G00 in front of it and did some other things. What I am trying to do however is take steel stock of Rockwell hardness 24 with a Diameter of 2" and work it down to 1 1/4". The piece I have is 4 " long and has been faced on both sides. I need to turn it down to 1 1/4" for a length of 2 inches and then I need a fillet beyond the two turned down length. I don't want a huge radius on fillet, it's just to reduce stress concentrations. I was thinking of using setting of 600-800 RPM 0.015 in/rev and 600 fpm. Advice on this would also be great but I figured I'd just try n stay conservative. Thanks so much. Getting this done by the end of the day would be great.
| Hi, Have you set your datum to the face of the job ie Z0. that might be why Z over travel. the error 603 Non MOnotonous PQ Blocks in Z might be because the way you had it writen it could not reslove the arc. What you move in Z you move twice the amount in a 90 Degree move on the X |
#11
| Regarding your Z overtravel are you sure your offset went into the correct tool number? The TLs have what I think is a glitch, the cursor will not always go to the correct tool on the Offsets page; you must push reset or move it yourself. I think your non-monotonous comes from here where you move to Z-2.13 then try to move back to Z-2.3 G01 X1.25 Z-2.312 G02 X1.226 Z-2.3 R-0.012 If it is not too late to impress the man put up a drawing (pdf file please) of what you want it to look like and I could do a sample program. Incidentally lose IPS, I think it is not worth learning if you want to eventually become fully proficient on the machine. I have my own template programs in which I just change coordinates. Turning something down with an end radius and a fillet radius is about a minutes work entering the new coordinate values and Z offset then push the Green Button.
#12
| Hey, I attached a drawing, i had to make it paint so it's not to scale or anything, don't ask. I just need the code for the part that is turned down to 1 1/4. And the Chamfer at the top isn't really important but it'd be nice.
| mill/turn on a cin turn | Robert Timby | General Metal Working Machines | 4 | 01-31-2007 10:33 PM |
| Which to Turn on First or Not | Mr.Chips | General Electronics Discussion | 10 | 01-31-2007 08:02 PM |
| Cin Turn turn/mill | Robert Timby | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-24-2007 07:12 PM |
| Help with selector switch wiring issue (***actually a motor issue***) | BEDFORD | Industrial Hobbies (Support forum) | 7 | 04-07-2006 03:19 PM |
| THC Issue | Aldoseri | CamSoft Products | 3 | 01-31-2006 04:33 AM |
