Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 10-13-2008, 06:17 AM
HAASboi's Avatar
HAASboi is on a distinguished road
G70 finishing cycle problem Haas SL20
I need a little help..I want to reduce RPM speed at G70 finishing cycle
my problem is G97S1300 didnt read still 1700 RPM
here' my program (42x120mm 4130 steel)
G54:
G0X200.Z150;
G96S1700;
G50 T0101 M03 S300; WNMG-04080404
X45. Z3.;
G94 X-2. Z3. F.25 M08;
Z2.;
Z1.;
Z0.;
G0 X42. Z1.;
G71 P01 D1.5 Q05 W.1 F.35
N01 G0 X30.6 ;
N02 G01 Z0. ;
N03 G03 X32.7 Z-1. R1. ;
N04 G01 Z-108.1 ;
N05 G02 X35.9 Z-112.2 R15. ;
G70 P01 Q05 G97S1300 F.19 ;
G28;
M05;
M30;
Val Hyder
Old 10-13-2008, 12:44 PM
rusticr6 is on a distinguished road
I think you need to put the G97 s1300 before the g70 line.
the way it is now it sees the g70, runs the finish cycle then it sees the g97.
Old 10-13-2008, 03:30 PM
Put the G70 speed in the P01 block and you can also change to a finishing feed.
Old 10-14-2008, 12:18 AM
pit202 is on a distinguished road
don`t you misunderstand the G50 and G96/G97 codes ?
you put G96 S1700 which is 1700 meters per minute cutting speed( this is too much even for alu ) and put G50 S300 which is mean maximum RPM is 300 .
Try to simulate this :
Code:
G54:
G0 X200.Z150;
G50 S1700;
G96 S300 M3
T0101 M06
X45. Z3.;
Z2.;
Z1.;
Z0.;
G0 X42. Z1.;
N01 G0 X30.6 ;
N02 G01 Z0. ;
N04 G01 Z-108.1 ;
G50 S1300
G70 P01 Q05  F.19 ;
M9
G28;
M05;
M30;
Old 10-14-2008, 02:51 AM
HAASboi's Avatar
thanks for your help guys it works..
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
Need Help!- New Haas sl20 control bullseye Haas Lathes 35 04-16-2008 08:39 AM
HAAS SL20 programmers help HAASboi Haas Mills 4 05-05-2007 08:39 PM
Problem with G76 cycle on HAAS SL20 MojosMachine Surfcam 3 03-16-2007 09:35 AM
HAAS SL20 Problem BobAllen Haas Mills 8 01-04-2007 03:55 PM
