Page 3 of 3 FirstFirst 123
Results 25 to 30 of 30
Thread: setting 51 door override
  1. #25
    Jul 2005
    Quote Originally Posted by pit202 View Post
    thanks , but I managed to turn off the " safety circuit " and now I can open doors whenever I wish , and this turns the FEEDHOLD , stops the spindle , I know this could be dangerous - but It really helps sometimes.
    I do not think this is really dangerous because the machine has stopped by the time the door is fully open. You can still get a coolant bath.
  2. #26
    Jan 2011
    So I just took delivery of a brand new VF1. My first real CNC machine.
    The tech told me that the door override is gone now on the new models. Can anyone confirm this?
    I have a healthy fear of the machine but periodically I do want to open the door and check on things.
    Is this possible?
  3. #27
    Jul 2005
    You can open the door but that will stop the machine.
    This has been covered in a couple of threads in the past few months. There is no Setting 51. The machines have a key switch or something, that can be turned on to allow limited operation for setup.
  4. #28
    May 2008
    ok, I read the whole topic, and I still does not know how to open door while the program is running , ok, don`t tell me that is dangerous I know that , I need sometimes to open doors after I stopped the spindle and turn off the coolant and the door lock is still closed, there is a one moment I can do that and that is only after tool change , sometimes the chips are not breaking and rolling on the part - and this is the only one need to open doors , to not reset the program . my setting 51 does not make any difference , and door stop spindle too. anybody help ?
    I'm probably breaking some international laws but who gives rat’s a$$.
    I made c-clips and put them right over the switches. I'm done forever.
    Attached Thumbnails Attached Thumbnails setting 51 door override-000003.jpg   setting 51 door override-000001.jpg   setting 51 door override-000002.jpg
  • #29
    Nov 2006
    Beware that the new machines can't use a simple "jump". They won't let you home the machine until the door is opened then closed (or until the machine thinks that happened).
    With some machines you can easily tape a penny over the switch but others it's not so easy.
  • #30
    May 2004
    Never quite understood all the "machinists" that can't work on a machine (at least the mechanicals).
    Okuma is similar. Can't complete machine power up and homing until switch is activated. I took the "key" off and placed in the switch body, then moved the switch body to a location near the control panel for easy access. Then can activate the switch easily when needed.
    http://www.kirkcon.com/
  • Page 3 of 3 FirstFirst 123
    1. Need Help!- how to override door
      By gregoryblaine in forum Hardinge Lathes
      Last Post: 09-08-2008, 04:32 PM
    2. Door Interlock override ? 18i-TB
      By YARKONE in forum Fanuc
      Last Post: 06-22-2008, 09:11 PM
    3. Need Help!- RAPID OVERRIDE
      By CNC_BOB in forum OKK
      Last Post: 06-02-2008, 06:34 AM
    4. Does Mach3 tool diameter override gcode setting?
      By WarrenW in forum Mach Software (ArtSoft software)
      Last Post: 04-27-2006, 09:09 AM
    5. Feedrate Override
      By JFettig in forum TurboCNC
      Last Post: 12-09-2004, 07:17 PM
