Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 09-19-2008, 12:05 PM
mcamiller is on a distinguished road
Question Haas TL-25 part transfer
I have to drill/tap three holes in the face of a part, cut-off and transfer to the subspindle, and drill/tap three holes in the back side of the part. I have to have both spindle oriented for the transfer, so here's what i have tryed.
I turn the front, stop main chuck, orient to zero, orient subspindle to zero, clamp subspindle, and try to turn both on simultaneously. As the part is turning, you can see it leaving marks from slipping in the subspindle.
M110 (clamp subspindle onto part)
G04 P2. (Dwell)
M04 S100 G04 P2. (Main spindle on, dwell)
M143 P100 (subspindle on)
Thanks, anyone who can help.
Old 09-19-2008, 08:56 PM
dfrey2@rocheste is on a distinguished road
I called our Hass rep the other day bacause the power meter for the sub would max out just before it finished cutting off. 1 spindle runs about 1 -2 rpm faster than the other at 300 rpm. I thought that there was a synch code for the Hass machines so that you could grab hex stock on the run so to speak and force the two spindles to run at the same speed. What I found out was they want to you let the sub just tag along until after it cuts off, back away from the main spindle, then start the sub to do that work. Sounds like you might have to do the same thing.
Old 09-22-2008, 04:16 AM
Unhappy Answer
I have since spoken to the Applications department at Haas and they had the same answer. It's dissappointing because we bought this lathe for this purpose, but i have found that you simply cannot sync the spindles. Even their demo video shows a part transfer with both spindles spinning, but i don't know how that is possible without having marks on the part since I've spoken to three separate Haas people and only found the same thing you are doing, which means the spindles will not syncronize.
Old 09-22-2008, 02:09 PM
bl409 is on a distinguished road
This is just a suggestion but it may work for what you are doing.
I would suggest that you run your cutoff tool almost al the way thru
your part and just leave it hanging on by a small stem then run your sub spindle on, clamp (with the sub spindle oriented) and just pull the part off.
It may take a few test pieces to findout how small to leave the stem but
it may get your job done on this machine. Just a thought.
BL
Newbie- Part holding and milling 3D part on 2.5D Mill? john_t_h General Metalwork Discussion 6 03-15-2008 06:35 AM
Missing steps on just a certain part of the part ZipSnipe Stepper Motors and Drives 5 01-02-2008 01:40 PM
285 alarm after part transfer Bobc007 Mazak, Mitsubishi, Mazatrol 0 04-18-2007 09:13 PM
how to transfer? hop General CNC (Mill and Lathe) Control Software (NC) 0 06-14-2006 11:35 PM
how to for 94 haas vf3 tool and part probe lapuser Machine Problems, Solutions , Wireless DNC, serial port 5 01-13-2006 11:43 AM
