Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 08-23-2008, 07:36 PM
GENMACH is on a distinguished road
TL-2 questions
I will be purchasing the TL-2 in the very near future. Here are some concerns. Any suggestions or comments would be appreciated. I am interested in the optional 4 station tool turret. A concern is if more than 4 tools are needed, is this easily removed & disabled in the control. Also, one the optional 3500 rpm motor, does anyone know if the low end torque would increase or diminish with this option or stay the same as the standard motor. Thanks in advance.
Old 08-23-2008, 09:23 PM
Originally Posted by GENMACH View Post
.... A concern is if more than 4 tools are needed, is this easily removed & disabled in the control.
Also, one the optional 3500 rpm motor,...
Removing and replacing tool turret?
Most emphatically not easy!!!!!!!!!!!!!!!
The olde style was easy to switch; the new servo driven one is half a day job.
I have made gang tool holders for various setups on the TL2; many times I use six tools and I think I might have managed a setup using seven once. I will see if I can find some pictures I posted.
The optional 3500 rpm motor?
You should search carefully on the Haas website, contact your dealer or contact Haas for more info. My memory tells me the 3500 rpm option is not a different motor it is a different spindle, or maybe different bearings on the spindle for the higher speed, but the motor is the same. If this is correct the low speed torque will be the same, I think, because the motor speed is controlled by a Parameter (or two).
Old 08-23-2008, 09:37 PM
All these threads have pictures I have posted showing tool holders and setups to get more tools on a turret by using gang tooling.
http://www.cnczone.com/forums/showthread.php?t=22010
http://www.cnczone.com/forums/showthread.php?t=33866
http://www.cnczone.com/forums/showthread.php?t=39471
http://www.cnczone.com/forums/showthread.php?t=44460
Old 08-25-2008, 09:52 AM
Juan J. Romero is on a distinguished road
Hi, I´m not speak english, but google translator help me, exist software to convert solidworks files to G-Code to Haas TL-2 lathe? directly?.
Thanks for your assistance.
Regards,
Juan
Old 08-25-2008, 11:35 AM
Regards,
Juan
I cannot answer this question but you could try posting it in this forum:
http://www.cnczone.com/forums/forumd...ysprune=&f=338
The language in Argentina is Spanish, I think?
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 03:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 12:40 PM
Newbie- Questions that I have.... James CNC DIY-CNC Router Table Machines 1 05-10-2008 11:38 PM
New guy here and have some questions Westjet9717 DIY-CNC Router Table Machines 0 09-20-2007 03:04 AM
New to CNC and I have A few questions. onem DIY-CNC Router Table Machines 12 04-08-2005 01:57 PM
