Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 07-30-2008, 12:45 AM
Venkatakrishnan is on a distinguished road
Question Haas SL10 BALL SCREW
Hello friends,
We recently changed (one year back) a new ball screw assy in Haas SL10 CNC lathe.Eventhough all of our periodic maintenence and lubrication system found ok, now the ball screw found damaged. What will be the causes for frequent damage? and how can we eliminate in future?.
Old 07-30-2008, 04:38 PM
DEAN is on a distinguished road
Damaged in what way??
Old 07-30-2008, 10:43 PM
Haas-SL10 Z-axis ball screw assy.
Thanks for your posting
While production in progress of a small aluminum component(0.75mm pitch threading),suddenly abnormal sound in Z axis movent observed. Machine stopped and end bearing conditions verified found ok.Then ball screw with nut sent for analysis to an expert.They observed that one lock nut ball diverter out of three (inside of locknut) found damaged. There was scorring marks found on the steel balls,but no burrs or other foriegn material observed inside the lock nut.
Could this be the manufacturing defect of the Ball screw assy?
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Haas SL10 Tailstock problem metal surgeon Haas Mills 4 09-04-2006 11:24 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
