Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 07-20-2008, 10:22 PM
rideredcr is on a distinguished road
TL-1 power supply problem
Haas Tl-1. I got an alarm for an X axis fault (161)when my machine rapid home for a tool change. I cleared the alarm and continued on with my program. When the machine rapid home for the next tool change I heard a loud pop, the spindle motor slowly wound down instead of breaking to a stop like normal, and it displayed an alarm for an OVERLOAD/ SHORT FAULT for the 320v power supply I believe the alarm code is 279. Also instead of an X axis fault this time there was a Z axis fault (163) along with the 279 code. Any guesses out there?
Old 09-03-2008, 01:48 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Man, I haven't been on here in awhile. I hope you got this fixed. My TL-1 also had some weird problems. It eventually popped inside the power supply. They replaced the power supply under warranty. I was also having startup problems with it blowing the breakers in my panel. After replacing the power supply, no more problems.
Greg
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Does anyone have stepper motor power supply problem? david_geng Syil Products 3 09-04-2007 01:02 PM
ATX 2 power supply problem flannman General Electronics Discussion 4 05-28-2006 01:19 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
stepper power supply problem bertvk General Electronics Discussion 3 08-20-2004 01:08 PM
