Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 07-08-2008, 08:55 AM
travis1 is on a distinguished road
SL-30 programing ?
can you run the tall stock in 2 different positions in the same program?
ive never ran a programmable tall stock before
also im pretty sure M25 is advance what would be the M code for the retract ?
Old 07-08-2008, 10:21 AM
theatrewizard is on a distinguished road
M21 is advance, M 22 is retract. Parameters can be set/changed as needed.
What ever your stop point is, set it 1" beyond, to maintain proper pressure onn the part.
Old 07-09-2008, 12:03 AM
fourcylthrill is on a distinguished road
You can command the tailstock to move to a certain point, ex. B-13.432, in MDI or in a program. I've never tried running a program like that though. I have always used M21/M22 so I'm not sure what the outcome would be.
Old 07-09-2008, 09:06 AM
well i just want to do it for show we had to kick and scream to get a new lathe so i though id write a program just to make it look cool im sure ill loose concentricity but hay who cares if it works as long as it looks COOL rite
? on programing markjb Fadal 6 03-16-2009 05:09 AM
programing help DARKWINZ Okuma 6 06-02-2008 09:23 PM
0-M programing help please venomgrrrl Fanuc 22 12-07-2007 11:51 PM
CNC programing Fryzss General CNC (Mill and Lathe) Control Software (NC) 8 10-27-2007 10:33 AM
CAM programing kenlambert G-Code Programing 1 02-03-2006 12:03 AM
