Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 07-01-2008, 10:08 AM
allmotormatt is on a distinguished road
over travel? WTF
im trying to learn our new lathe its a sl-40 longbed everytime i go to run a program it says z axes over travel or if its not z its x i tried to set the tools and work offsets but i just cant get them right if anyone can explain how to set tools and work offsets to get my programs running please help
Old 07-01-2008, 02:36 PM
theatrewizard is on a distinguished road
What I've found in the 6 short months that I've been using a Haas, as far as overtravel alarms go, all things are relative. Where the turret is when you hit cycle start, where the Z zero point is, and does the turret move on the X or Z axis first to get to the start point. Every day I discover something new about our SL 30. Be sure that you don't have any misplaced decimal points in the X or Z coordinates. IE z 2.0 not z 2
Old 07-02-2008, 12:42 AM
HuFlungDung's Avatar
Moderator
Did you follow the instructions in the Haas lathe manual? It seems fairly succinct.
I don't have a Haas lathe, but the controls look similar enough to mill that I can perhaps anticipate your problem. Plus, tool settings on lathes are all based on the same set of variables.
When you touch off the tool and press the X dia measure button, that only inserts a value for the distance of the tool from machine home, so its only a partially complete process. Then, you have to key in the diameter and press Write. When you do that, an addition (or subtraction) is performed on the value that was automatically inserted by the X dia measure button.
The online manual describes this procedure for OD tools, but for ID tools, they neglect to tell you to key in the ID measured value and press Write to correct the X dia measure value. I assume it would be the same procedure for both OD and ID tools.
What values, if any, would you be using for your primary work offset (commonly G54)?
Anyways, maybe this will bump this thread up to where some of the experienced Haas lathe guys can give you some more tips.
Old 10-06-2008, 06:03 AM
VoKuS is on a distinguished road
Did you touch off your tools correctly?
Did you set a G54?
Is the program you are running asking the machine to move more then its capable in the X or Z axis?
Say you have a turn tool, its touched off and g54 set, but the program is asking the tool to move 100" in Z instead of 10"... Things like that...
Is the tool number matching in the program to the tool you touched off..
^^ It happens lol.
rapid travel iccirvr Mach Mill 8 05-19-2008 11:10 PM
X3 X-axis travel mod pzzamakr1980 Benchtop Machines 10 03-30-2008 02:28 AM
New Machine Build- 400-600mm z-travel?? perolalars DIY-CNC Router Table Machines 0 03-10-2008 03:01 PM
Problem- Fanuc OM over travel malasjo Fanuc 5 03-10-2008 11:37 AM
Have ballscrew will travel/how far? lgalla Linear and Rotary Motion 0 01-10-2007 08:39 PM
