Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 06-17-2008, 09:38 PM
Max rpm on TL1
This has, I think, been discussed before, but I am way too lazy to try and find it. What Parameters have to be changed to alter the maximum rpm on the TL1? I want to set a maximum of 600 rpm. I know it can be done with G50 in the program but I want to limit the machine itself no matter what is put in a program.
Old 06-18-2008, 12:11 AM
pit202 is on a distinguished road
Try :
Parameters -> Spindle -> Spindle max rpm <if not>
Parameters -> Sp -> Max Freq
Old 06-18-2008, 12:54 PM
Thank you Piter, that helped me remember; Parameter 183 Max Freq and Parameter 131 Max rpm.
Now I have the slowest TL1 in the world; 600 rpm max.
Old 06-20-2008, 07:07 AM
Peter Gibbs is on a distinguished road
Talking
HEY Geof what are you up to mate , new apprentice , or you letting your missus play with the lathe.. peter
Old 06-20-2008, 07:40 AM
PBMW is on a distinguished road
I'm thinkin unbalanced work piece....
Old 06-20-2008, 09:04 AM
This is the TL1 that we use for finishing the ends of stainless steel tubes that I bought over a year ago. I started building a long bar feed, (tube feed really,) and was then diverted onto other projects for a while but now the feeder is almost finished. It is a 20 feet long rotating carrier driven by the spindle with an air injector system to advance the tube. We have tested it to 1000rpm but the idea of having it run at 2000 if someone punched a wrong button kinda scares me so that is why the machine is now limied to 600rpm.
I will take some pictures when it is finished.
