Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 03-29-2008, 07:45 PM
APP APP is offline
APP is on a distinguished road
I keep getting a c-axis alarm
alarm 622 c-axis engagement
It will do it every time, but if I reset two or three times it will run fine.
There are two micro switches in the c drive. If I put a shim under the one towards the rear of the machine, it runs fine, but the c-axis is off. It doesn't index the same every time.
Help.
2003 TL-15
Old 03-31-2008, 10:19 AM
APP APP is offline
So I think I figured it out.
There is a piston in the drive axis mount that when presurized with air rocks the mount and then drive connecting the drive gear, and the gear on the spindle. I am thinking that the o rings are just not sealing as well as they used too.
I will replace them today and report back.
Old 03-31-2008, 01:04 PM
serviceman's Avatar
serviceman is on a distinguished road
you need to do the c axis grid offset and the gear mesh contact load first then go from there.
REYTECH Machine Service Corp. CNC repair NY, NJ
http://www.reytechmachine.com
Old 03-31-2008, 01:12 PM
APP APP is offline
Could you tell me how?
Old 04-15-2008, 01:01 PM
APP APP is offline
I havent been using the live tools for a while, but i have a job running now that is using them, so I have had a chance to play around some more with this problem.
I have an air supply issue. I have plenty of air at the regulator, but there isnt enough pressure getting to the c axis to engage. I havent had an air dryer, and think that has caused this issue.
Will report back when I find the culprit.
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Y-axis servo alarm #329 MIYANO vs FANUC Fanuc 3 01-12-2008 10:38 PM
Alarm,24&34 on Y-axis -only on rapids Robmatsuura General CNC (Mill and Lathe) Control Software (NC) 1 11-19-2007 09:14 PM
Keep getting z axis overtravel alarm 146 dragon864 Haas Mills 3 07-20-2007 06:13 PM
4th axis alarm johnmckeown Haas Mills 2 04-13-2007 05:54 AM
