03-18-2008, 08:04 AM
Unlike Donkey said, I will suggest to LEAVE setting 36 to ON because if you turn it off, the control will not check command BEFORE the line you've selected. From Manual : 36 - Program Restart
When this setting is On, restarting a program from a point other than the beginning will direct the control to
scan the entire program to ensure that the tools, offsets, G and M codes, and axis positions are set correctly
before the program starts at the block where the cursor is positioned. The following M codes will be processed
when Setting 36 is enabled:
M08 Coolant On M37 Parts Catcher Off
M09 Coolant Off M41 Low Gear
M14 Clmp Main Spndl M42 High Gear
M15 Unclmp Main Spndl M51-58 Set User M
M36 Parts Catcher On M61-68 Clear User M
When it is Off the program will start without checking the conditions of the machine. Having this setting Off
may save time when running a proven program. |
Try this instead :
Press EDIT btn;
Scroll to the line you want to restart;
Press MEM btn;
Press Curnt Comds btn;
And give it a start, it should work. |
