Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 03-06-2008, 06:02 PM
Aeon is on a distinguished road
How to setup and program sub-spindle on TL-25?
How to setup tools for the sub-spindle? use the "twin turn" or the "twin bore" tool holders, how to set the other side? the main spindle side use the probe, what about the sub-spindle side?
After the part passed off to the sub-spindle, and using G14, where is the Z0. ?
If I wanna use the sub-spindle to grip the part (for example) G54 Z-.5. Is it possible to know where is the front of the jaws on the sub-spindle, and the relation between the B0. and the G54 Z0. ?
Thanks!
A Axis and Step and Direction Spindle Setup mklb Mach Software (ArtSoft software) 6 11-27-2009 07:19 AM
Example CNC machine Setup Sheet + program backup lug_wrench Machine Problems, Solutions , Wireless DNC, serial port 4 10-14-2008 08:24 AM
Job Opening CNC Mill, Horiz and Vert Setup, Operate and program MaddMike Employment Opportunity 5 02-01-2008 08:04 PM
DMU 50 Evo Linear iTNC530 - Setup Program Needed Lackey92 Deckel, Maho, Aciera, Abene Mills 3 11-18-2007 10:13 PM
Old lathe spindle setup PIngels General Metal Working Machines 14 12-06-2006 10:15 AM
