Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 03-06-2008, 11:40 AM
djr76's Avatar
djr76 is on a distinguished road
HL-2 close chuck, delay, cycle start
Is there a way to use the foot pedal (close chuck), to close chuck, delay a predetermined time, then cycle start without hitting the green cycle start button? That way you're not turning to the awkward position behind you to hit the button on the control panel. FYI, its just facing and putting a small radius on without coolant, so the door is left open with the door switch overrided. Thanks for any answers in advance.
Dave
Old 03-06-2008, 11:58 AM
There could be but that may be a high risk procedure.
You have the door switch disabled already. To avoid the machine alarming when the chuck is opened mid-cycle, which is what you will be doing, you would need to change the Parameter (or Setting, I forget which) that allows you to open the chuck when a cycle is running, and the only way to get the machine to restart by itself without hitting the button is to have a G04 dwell.
So if you took too long opening or closing the chuck...if someone distracted you...the machine is going to fire up with you wrapped around the chuck.
I know if I caught one of my guys doing that I would 'fire up'.
If I worked for a Boss that told me to do that I would get a new job.
Old 03-06-2008, 12:02 PM
djr76's Avatar
lol, damn Geof, ninja reply. Its my boss thats running the part. When he came to me and ask if it can be done I thought the same thing as you as losing fingers in a heartbeat. I'll tell him it cant be done just for the sake I like the guy lol.
Old 03-06-2008, 12:21 PM
Originally Posted by djr76 View Post
....Its my boss thats running the part.....
Can he still count up to ten without using his toes?
Fanuc O-T chuck open/close M-code Ztiggi Fanuc 12 01-29-2008 06:27 AM
Remote cycle start REVCAM_Bob Fanuc 6 03-18-2007 07:08 PM
Chuck close in program Rocksalt Fanuc 3 10-25-2006 01:31 PM
Start delay on Thermal Dynamics 151 Scratch CNC Plasma and Waterjet Machines 4 06-01-2006 11:22 AM
Cycle Start button kaleem1 Mach Software (ArtSoft software) 7 12-24-2005 02:05 PM
