Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 03-05-2008, 03:56 PM
Hellbringer is on a distinguished road
Hydraulic/Air Chuck?
Hi i was woundering if someone could shead some light on how a computer controled hydraulic/air chuck works. also i see that some of the cnc lathes use a collet disign to grip the stock, the biggest collet i can find is 1.25" is that the bigges stock you can do with a chuch system?
thanks for you help in advance
Mike
Old 03-06-2008, 03:09 PM
philserveng is on a distinguished road
absolutely not, collet chucks can be very large diameters. The difference is that chucks can grip more firmly and are more suited to billet work (hand loaded). Collets are more suited to bar work where a barfeeder is used.
They work in similar ways, except that a collet chuck is pushed by the draw tube and the 3 jaw chuck pulls the draw tube to clamp the work. Both systems need valves to actuate the stroke of the draw tube and both need switches to monitor the function. See M10/ M11 codes for this function.
hydraulic help byoung0454 Mechanical Calculations/Engineering Design 4 01-08-2008 10:29 PM
Hydraulic Problem bherr Bridgeport and Hardinge Mills 0 06-28-2007 04:07 PM
Which Hydraulic Oil do I use????? bherr Bridgeport and Hardinge Mills 2 06-12-2007 08:01 PM
hydraulic chuck Runner4404spd Mini Lathe 9 02-11-2007 04:46 PM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 01:20 AM
