Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 03-04-2008, 04:42 PM
qnet2 is on a distinguished road
using a bar puller for first time
hey guys
using a bar puller for first time on a haas sl-30
prog runs on graph but errors out on pulling part out to position
because jaws are not clamped. How do i disable this so i
can use my bar puller?
thanks
Old 03-05-2008, 09:21 AM
never mind it's because the lathe was in singleblock
Old 03-05-2008, 09:25 AM
I went through that one and got very frustrated.
Now I put M01 just after the pulling sequence so I can turn single block off, have optional stop on, and then pick up single block again after the pull.
Good Bar Puller AMCTony Haas Lathes 10 09-29-2007 11:45 PM
Mini jaw puller? mikesativa General Metalwork Discussion 7 04-18-2006 11:21 AM
Bur Puller programming Genie Mazak, Mitsubishi, Mazatrol 5 02-07-2006 06:48 PM
Wheel Puller TCAJAX Fadal 3 10-20-2005 01:12 PM
Bar puller on Fanuc 18t 2seatramp G-Code Programing 3 10-09-2005 09:10 PM
