Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 03-03-2008, 07:10 PM
allmotormatt is on a distinguished road
offsets help please.
does anyone know where i can find step by step instructions on seting tool offsets and worshift offsets on a sl-40? i keep getting a z axis overtravel range everytime i go to run the program i made. i can machine in m.d.i. after i set worshift offsets in g54. i think im doing sumthing wrong when i set my offsets. any help would be appreciated!!! thanks
Old 03-03-2008, 07:36 PM
Go to the haas website; haascnc.com
In the upper right corner of the front page is; site map so click on this.
Then scroll down and you will see things like manual updates, literature request, or things about manuals.
You will need to search around a bit but eventually you will find Lathe Manual which is a pdf file of the entire thing you can download. What you need will be in there.
Offsets not big enough! John3 Fanuc 19 02-07-2009 09:03 PM
Need help on protecting offsets gregmaurer General Metal Working Machines 5 11-05-2007 09:06 AM
Using WC Z offsets Shotout Haas Mills 2 04-26-2007 06:06 AM
G54 offsets questions turmite G-Code Programing 1 08-10-2006 07:00 PM
Canceling G54 offsets.... howling60 CamSoft Products 6 12-15-2005 06:11 AM
