| Haas Lathes Discuss Haas lathe here! |
| I'm in the process of building one now. It's going to be able to accomodate up to 10" diameter material. I'll make sure that I post some photo's of it when it's completed. I'm making it out of 6061, few little stainless parts and some brass and bronze. Will be some bearing rollers and what not. I'm also making it so I make it usable for smaller material also. Basically by changing one piece. Being limited to size constraints This will be a sick little addition to my TL |
That looks very nice.
| Boy, that is something to be proud of. That's a nice looking piece of tooling. Are you confident that the aluminum is stiff enough to do the job for you? Even if it's not as strong as the Haas supplied one, I'll bet yours is more versatile (size).
__________________ Greg |
| Yeah the aluminum I'm using is 2" thick. The part I'm going to spin is 9" round tube with 3/4" wall. I don't plan on running it at a 1000 rpm or anything, although that might be fun, it's probably not the safest. Once the i.d. is turned I'm going to use bungs on the end and turn the length of the tube. I just finished the top half yesterday. I have to finish the lower main of the body. The rollers are done, I also need to finish the adjustment screws. Should all be done by the end of the week. I do have to remove the drip pan on the carriage for clearance though. Not a big deal IMO. I'll make sure you all get a look at all the components when I'm finished |
| cross slide and compound rest | krymis | Mini Lathe | 2 | 02-09-2008 09:42 PM |
| Open Steady rest | Loelco | General Metalwork Discussion | 1 | 02-07-2008 04:29 PM |
| rest machining | camtd | BobCad-Cam | 4 | 09-04-2007 06:52 PM |
| Haas VF2 , master cam, catia v5 vs the rest | aussie28 | Haas Mills | 9 | 08-12-2007 10:31 PM |
| Steady rest auto self centering work | trh400 | General Metalwork Discussion | 1 | 12-22-2006 12:00 AM |
