| Haas Lathes Discuss Haas lathe here! |
| Hi, We just got a HAAS TL-4 Lathe. I have been doing the programming for our Mills for about five years now, but this is the first lathe I will have programmed. At this point my main concern is how to use the tool nose radius compensation. I would like to have the Program do all the compensating for the radius on the tool just as with programming using centerline programming on the mills(no need to but a tool diameter or radius in). I use FeatureCam for most of my programming but I also have MasterCam and SurfCam. I can see many obsticles because of it being a toolroom lathe but I will start with this one. Speeeeeeeeeeeeeeed |
| Everyone has their own way to do thing, but I found programming on the lathe the easiest is program with 0radius, then put tool radius and direction in the offset and machine will take care the rest. I knew you working with milling for so long and found it diffcult the new idea. Machinist end up stuck with same tool/let say it create chatter........ end up rewrite program.
__________________ The best way to learn is trial error. |
| Config your featurecam so it will program it. Mine was doing it but I prefer to make the control do the job in a canned cycle. After if I have a similar part but different dimmension, I just have to change the profile wants and don't botther with the tool comp. But hey, all roads leads to Rome! |
| Don't make the same mistake. I scrapped a lot of brass that day.
__________________ Greg |
| tool nose radius comp | joe1970 | G-Code Programing | 8 | 02-24-2010 09:43 PM |
| 6T - tool nose compensation | Bluey | Fanuc | 2 | 10-10-2007 07:51 PM |
| nose radius compensation in fanuc tb-mate | rags | Fanuc | 2 | 09-29-2007 03:57 AM |
| G143 Nose Radius Comp. - Hitachi Seiki HT23J | jbird68 | G-Code Programing | 3 | 08-02-2007 11:41 AM |
| Tool Nose Radius Fault with Program | Josh-PTP | Haas Mills | 4 | 06-30-2007 05:03 PM |
