Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 01-17-2008, 09:53 AM
Edster is on a distinguished road
SL-10 Coolant Drain Upgrade
I just thought I share the Coolant Drain Upgrade experience with you guys. I got the updated drain through Haas for free, and we finally got a little time to install it. Actually we were trying to clean the intergal coolant tank on the SL-10 to switch to Liquid Ice coolant when I discovered Haas puts a nice baffle in the tank to keep chips from clogging the pump. Basically it was just a chip trap, and I removed a 5 gal bucket of chips from the coolant tank under the chip pan. I was starting to wonder why it was only taking a little over 10 gallons of coolant to fill the machine Anyway we decided to install the drain because we had to take the machine apart anyway to remove the POS baffle.
A few pics if anyone is interested.
http://www.ewwenterpriseinc.com/images/drain1.JPG
http://www.ewwenterpriseinc.com/images/drain2.JPG
http://www.ewwenterpriseinc.com/images/drain3.JPG
http://www.ewwenterpriseinc.com/images/drain4.JPG
http://www.ewwenterpriseinc.com/images/drain5.JPG
http://www.ewwenterpriseinc.com/images/drain6.JPG
http://www.ewwenterpriseinc.com/images/drain7.JPG
http://www.ewwenterpriseinc.com/images/drain8.JPG
http://www.ewwenterpriseinc.com/images/drain9.JPG
Ed
Old 01-19-2008, 07:57 PM
SeymourDumore is on a distinguished road
Ok Edster, do you have a part number for that thingy?
I want one, and I want one right now!
Old 01-20-2008, 09:49 AM
I don't have a part number for the drain. I replied to a post a while ago about the original drain plugging and flooding the chip pan. Some one from Haas saw the post and contacted me about the updated drain. They sent it to me free, and in a few days They even sent me a few solidworks files to show the location of the drain. I couldn't believe it. Great support if you ask me. I'm not sure of the guys name anymore, I've had the drain for over a year now. Just got around to installing it.
Have you had your chip pan apart? I couldn't believe the ammount of chips that were directly under the chip pan. Haas could have at least mentioned that it might need to be cleaned. You know they have stickers saying the basket strainer under the pump needs to be checked, but I was not prepaired for what lay under the chip pan. All caused by the stupid baffel that Haas put in the tank. I guess it's to stop chips from clogging the basket strainer. No wonder there were never any chips in the part of the coolant tank where you can actually clean it. They were all stuck under the chip pan where you have to dissassemble something to clean the tank. Oh well that baffel won't be causing me anymore trouble
Old 01-20-2008, 10:01 AM
One more thing. Cleaning the coolant tank will be much easier with the new drain and the baffel removed. I can rinse down the tank through the new drain and all the crap will flow down toward the pump where it can be easily removed.
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 01:20 AM
upgrade coolant pump alabat Daewoo/Doosan 2 02-06-2007 12:40 PM
coolant not working after upgrade mark c Machines running Mach Software 1 12-03-2006 07:43 AM
coolant not working after upgrade mark c Mach Software (ArtSoft software) 0 11-26-2006 06:48 PM
BP CNC Upgrade contractdesign Bridgeport and Hardinge Mills 20 08-15-2006 04:08 PM
