Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: The latest my SL10
    Aug 2005
    The latest my SL10
    So, Yesterday I was setting up my little SL10. Got the program running pretty good when a half inch screw machine drill went away.
    Go get another one from the tool room...put it in and whip out the tool probe. Beep...beep. Hmmm. Them numbers look just like the numbers what was in there before...
    So I put in 0.0 in the Z offset and re probe the drill. The machine don't stop but the probe beeps. Hmmm.....
    Shut it down nad re boot it. Same thing. So I fudge factor the tool offset and get to running, thinking well, it's about 60 days and time for something else to bust on this thing.
    This morning it's time for another drill....
    Probe works fine.
    Now THAT's enough to make me have a bunch of confidence in this thing!
    Jul 2005
    Some time in your past you must have really annoyed Murphy.
    Aug 2005
    You may have a point there Geof. You may have a point there...
    Oct 2003
    How much overtravel do these probes have? It would suck to bust the probe like that.
    Aug 2005
    Well, that was one of my first questions...
    Apparently quitea bit. I touch nad get my finger off the button as soon as I hear the beep. I happened to look at the number before hand and it was still that number. That got my curiosity up...
    Don't know just how much overtravel thay have but thankfully, I didn't exceed it!
    Oct 2003
    were you jogging in .001 increment? I know the probe beeps but doens't record the number if you in .01 or .1
    Aug 2005
    But of course....
    Registered Loose Nut's Avatar
    Sep 2006
    Check the home switch next to the socket that the probe sits in on the bulkhead.
    If the probe home switch is stuck (roller type) or has a chip on it (proximity type) it will do the same thing.
    Loose Nut
    Aug 2005
    Ahhhh....I'll check that. I was running a BUNCH o f303 parts pretty hard and the chips broke nicely. They were EVERYWHERE in the machine.
    Aug 2005
    I believe mine has a prox switch. No roller switch. Could have been a chip. All's well now though. Self healing! Gotta love that!
    Jul 2005
    Quote Originally Posted by PBMW View Post
    ..... Self healing! Gotta love that!
    My favorite solution. Turn off main power, cross fingers, look beseechingly at the control and turn power back on. This has worked numerous times and my 'technical' diagnosis for the original fault is that a stray cosmic ray came through and reset a bit somewhere.
    Aug 2005
    Well that's what I tried right off the bat. I mean...No sence wastin time. Shut it off. Waited a prudent ammount of time nad fired it up. Same thing.
    I did get through that job by fudging the comp a bit....
    Cleaned up the machine and Lo and Behold....it worked again.
    I think it was a chip.
  • Page 1 of 2 12 LastLast
    1. SL10 dies yet again
      By PBMW in forum Haas Lathes
      Last Post: 12-17-2007, 10:19 AM
    2. SL10 dies again
      By PBMW in forum Haas Mills
      Last Post: 05-15-2007, 04:45 PM
    3. Need Some Advise - SL10 or SL20
      By Josh-PTP in forum Haas Mills
      Last Post: 03-14-2007, 05:18 PM
    4. One Million Tool Changes On Sl10
      By Geof in forum Haas Mills
      Last Post: 02-26-2007, 04:26 PM
    5. Haas SL10 Tailstock problem
      By metal surgeon in forum Haas Mills
      Last Post: 09-04-2006, 12:24 PM
