Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 01-15-2008, 02:00 PM
Ceramic Man is on a distinguished road
Question Feed Overide 999%
How the heck do you get feed overrides to go from the factory 200% max to the advertised 999%? I run 4 GT lathes and a VF-2. After an HFO guy came to install the new VF-2, it allowed feed override to go to 999%. I'm pretty familiar with parameters and settings, but can't find anything that looks related. There is an "Unused" setting in "Parameter 57" that is set to 1 on the VF-2 that was 0 before the guy came. If I try to change it on the lathes, it requires a code. Is this the setting I'm looking for?
Old 01-15-2008, 05:40 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Do you have a "Handle Control Feed Rate " soft Key??
If you do, then you push that key to activate the function. Then use the jog handle to Increase / Decrease the feed rate.. Same for spindle speed override..
If you don't have that soft key, you will not be able to do this..
Old 01-15-2008, 06:26 PM
First, sorry for starting 2 threads on the same thing. This is my first time posting here and I thought my thread didn't get posted the first time and re-did it. I will get rid of the other one.
Ok, I have the handle control feedrate, but whether I use it or the +/-10% buttons, the most it will let me do is 200%
All our machines are 2006 and 2007 models, but I don't think it matters for this. 2 GT-20s (2006), 2 GT-10s (2007) and a VF-2 (2007).
Old 01-15-2008, 10:43 PM
wms's Avatar
wms wms is offline
Moderator
After you select the Soft key..then use the handle jog dial to increase or decrease the rate..not the +/- buttons..
Old 01-15-2008, 10:57 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Where did you see 999% advertised? It seems like that would be a useful feature. I can see pre-running a complex contouring path and wanting to speed up the feedrates through known areas or to recut a spring-pass run over the same part again.
Greg
Old 01-15-2008, 11:11 PM
See the picture. Push the circled button then turn the Jog Handle.
EDIT: But not on TL or TM, 200% is the limit on these machines.
Old 01-15-2008, 11:38 PM
Hmmm...it's been awhile since I've done that on the VF-2. Maybe it is 999% and I'm confusing it with the TL-1.
I'm making my first ball-contoured parts in the VF-2 this week. I guess I'll find out soon enough.
Greg
Old 01-16-2008, 09:37 AM
Our VF-2 does go to 999% now, but it would only go to 200% before the haas technician messed with something. It would be more useful on the lathes since all we do is ceramic, feedrates are usually very slow.. like .00005 in/rev at 200 rpm on ZTA (zirconia toughened alumina) for roughing! Sometimes by the time the cycle is done, a diamond grinding wheel has worn down several tenths. And a couple tenths is usually the tolerance i'm dealing with, so I have to change the offset and let it run through the whole thing again. Very tedious.
In response to wms:
200% is all it will do. whether using jog handle or not.
Old 01-16-2008, 09:43 AM
I went and checked on a few machines.
Mills have the 999% override, that is VF and MiniMills.
Lathes do not, they peak out at 200%.
Old 01-16-2008, 09:51 AM
Ahhh, darn it. Well, this isn't over yet. I'm gonna call that tech and make sure if the feature can or cannot be enabled on the lathes. If I find out that it can be, I will post here on how to do it.
Old 01-16-2008, 12:03 PM
wms's Avatar
wms wms is offline
Moderator
Sorry thought the lathes where the same as the mills..Good luck.
  #12   Ban this user!
Old 01-17-2008, 01:29 PM
Dr Honda is on a distinguished road
Be VERY careful when using that feed rate. I accidentally left mine at 999% and went into a tool probing cycle on my VF3. Needles to say… I found out that the little brake away post works on the tool setter. And luckily… the machine hit the “Z” brakes before the tool hit the table. (I’m an idiot)
distance to go screeen? rapid overide? maranatha777 Mach Mill 0 03-19-2007 08:51 AM
DX-32 automatic corner overide ? RedGTZ Bridgeport and Hardinge Mills 3 12-29-2006 10:06 AM
Feed Rate Overide problem Moondog Machines running Mach Software 0 06-14-2006 05:35 AM
Feed ? Ken_Shea General Metalwork Discussion 12 10-31-2004 06:37 PM
Where is RSS feed? samualt Forum Questions or Problems 1 08-04-2004 07:04 AM
