Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 12-30-2007, 01:45 PM
WOLOG's Avatar
WOLOG is on a distinguished road
New SL-30 model
Has anyone heard anything about the Sl-30's being redesigned? It seems Haas is not saying much about this.
Old 01-03-2008, 01:12 PM
Haas_Apps is on a distinguished road
New SL-30
The SL-30 is not being re-designed. Haas does have new models in the works that could be confused with a re-design.
Old 01-03-2008, 04:14 PM
WOLOG's Avatar
Haas Apps,
I probably should not go into detail considering this may be sensitive to Haas operations and ongoing development of the lathe line. If you are willing, I would discuss this through PM's.
Old 01-03-2008, 07:30 PM
SeymourDumore is on a distinguished road
I beg you, make one of these "new models" a gang tool!!!
A Real gang tool with lotsa' X travel to get 8 tools around the collet!!!
An SL10 size with more X would be GREAT!!!
I beg you, pleeeese!!!
No need to reply, just Do It!!!
Old 01-03-2008, 07:43 PM
AMCTony is on a distinguished road
If you make it, they will buy!
Old 01-04-2008, 12:51 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
I'm curious as to why you'd want such a machine? Still learnin' around here.
Is it the saved cost of a tool turret? Or speed without having to change tools? Or repeatability?
Greg
Old 01-04-2008, 11:15 AM
Donkey
If you mean the difference between a turret and a gang style machine, then the most simple answer is: SPEED!!
If you take away all your motions involved with moving the turret away, changing the tool, moving back, ramp the spindle up, down etc etc etc...
Put it this way. I'm not one to play it safe with lathe programs. Many toolchages occur no more than .25" away from the part, ramp on and offs are combined with the toolchage moves etc. Even in these kind of conditions, identical part program optimized for the MiniLathe run minimum 20% faster cycletimes than the SL10.
Tool to tool distances are 2", going from center drill to drill means rapid from the R-plane of the spotter to the R-plane of the drill. Quite literally, you can go from the spotter dwelling at the bottom of the hole to the drill contacting the part in one second.
Go from finishing the OD of the part to cutoff tool at X and Z clearance in 1 second.
The last move in the roughing operation is actually the X/Z clearance move of the finishing operation.
Etc etc etc.
For the right job, the gangbusters are the perfect alternative to a full blown screwmachine.
Old 01-04-2008, 11:45 AM
They had one a few years ago called the Mini Lathe. Smaller than SL10 with a 5C collet. It was discontinued because there was not enough demand I was told when I considered ordering one.
Gang tooling certainly does increase speed but it is sometimes difficult to get enough tools without things fouling. I find the best compromise is to gang tools on the turret when possible to reduce tool changes and once a program is proved out tweak all my clearances for tool changes. You only need 0.1" clearance between things for a tool change and don't need to retract several inches and the time saving does add up even with 1000ipm rapids. On a TL with snail like rapids it saves a lot of time.
Old 01-04-2008, 12:32 PM
Oh, my friend Geof.
I do own a MiniLathe, and for the most part LOVING IT!!!
About the can't get around thing... HAAS has designed this thing Brilliantly in my opinion. The table is not straight all the way, rather half of it is made at a 45deg, so OD tools can be ganged up with just over 1" stepovers.
In addition the 5C collet nose is long and skinny, so the collision issues are greatly reduced.
Believe me, there is no way in hell any other machine with only 12" of X-travel can match this thing in versatility. Hardinge is nice and robust, but could not put on the setup I currently have on mine as we speak.
Tool1: Top Notch TNR .062
Tool2: 1/2" laydown threading
Tool3: WNMG 432 (1" shank)
Tool4: VNMG 331 (1" shank)
Tool5: Micro100 boring bar - (finish)
Tool6: Circle 3/8 boring bar - (rough)
Tool7: 7/16 drill
Tool8: Internal threading - 3/8 shank
The part is 7/8 dia, hangs out 1.800, the OD work goes as close as .02 from the collet nose, while the ID is bored 1" below, and the internal threading is .5 below the nose.
Not without special tooling would you be able to do that on most gang lathes.
Daewoo ( or Kia perhaps ) makes an 18" X-travel machine, but most are only 12, which leaves absolutely no room for proper tooling.
Also, if you have the ability to use 1" toolholders, you have access to just about anything and everything out there. Selection for 3/4 and 1/2" holders are very very limited or pricey from the specialty suppliers.
As for why they've stopped it? I don't think it was that there is no market for the Mini, rather it wasn't given a chance to show it's colors. With a little more time and a proper marketing push, I do believe it could hold it's own with the best of them.
The only thing would need to be changed is to undo the Engineering Disaster of a bed design it has to make it more rigid. It is on a solid, heavy casting, has a 7.5HP/6000RPM spindle, air OR hydraulic collet closer, A2-5 spindle nose, ample coolant tank, chip auger... the works.
I even thought of a way to fix the rigidity issue ( stupid stupid stupid design )so there is very little need to be done to bring it back.
Old 01-04-2008, 06:07 PM
Gang Tool Lathes
Have you taken a look at the GT-10 and GT-20. Both are standard gang tool machines.
  #11   Ban this user!
Old 01-04-2008, 06:20 PM
But both have very limited X travel.
  #12   Ban this user!
Old 01-04-2008, 07:02 PM
Hmmm...fascinating stuff guys. Thanks.
I figured that tool-to-tool time was the concern. Man, you've gotta' be banging out a lot of parts to care about a few seconds here and there. But now I see what you're comparing to (screw machines).
Greg
what model is this? teamjnz Tree 4 03-14-2008 01:46 AM
X3 Cad model nlancaster Benchtop Machines 11 11-12-2007 04:01 PM
which model is this james12s Industrial Hobbies (Support forum) 11 06-20-2007 06:39 AM
can anyone help with this model? wedgie OneCNC 1 06-13-2007 05:39 PM
Looking for someone to do 3-d model seansear Employment Opportunity 5 08-13-2004 03:39 PM
